Graupner speed 900 Torque
Home › Forums › Beginners › Graupner speed 900 Torque
Viewing 24 posts - 1 through 24 (of 24 total)
  • #65653
    Graeme Linskey
      @graemelinskey75588
      Hi There,
      My speed 900 torque has died on me so thinking about a brushless motor what sort of motor could match the 900 as I am cluless about how many poles KV rating to match the 900 in torque for the same voltage I was running it on a 3s Lipo but would like a bit more grunt
      Thanks
      #2594
      Graeme Linskey
        @graemelinskey75588
        #65654
          Hi Graeme
          The Hobbyking 3639-750kv(600watts) 3S (11.1vollts)8325rpm.
          Or the 3648-600kv(800watts)3S(11.1volts)6660rpm.
          These are 36-37mm dia. shaft 5mm.
          The kv rating is the number of revs per volt.
          Hope this helps!!!
          #65659
            Graeme
            The 900 used a nominal voltage of 12v for its quoted performance, which was 6500RPM; maximum efficiency @ 8A. That's not a powerful motor by comparison with most brushless motors (it's just 96W). I would suggest a brushless with a case of at least 42mm diameter (to give the torque) and maybe 500-600kv, which will give roughly the same speed as the 900 on the same voltage. Don't try comparing the quoted power figures!
            Here's one I found on Component Shop's website, but note it's rated as needing at least 4S (14.8v). **LINK**
            If you really want some serious grunt from 3S upwards then there's always this one **LINK**
            Dodgy Geezer 1
              @dodgygeezer1
              Posted by Dave Milbourn on 27/05/2016 09:48:48:
              …or he could use a couple of these…**LINK**
              laughlaugh
              #65672
                I have just picked my jaw up from the floor, where it fell having looked at DG`s link……..
                Yes, these brushed motors don't actually put out much power, despite their reputation, and that's why everyone thinks brushless are so much better because they fit motors of quadruple the power to that initially fitted and say "cor these brushless motors are so much better" which on the face of it they would be.
                My Project No3 has a dinky 28mm brushless motor, one of which (in this series of motor options) will produce 133W..on the face of it, a 900 upgrade easily, but of course it isn't is it? its just too small to do what a 900 does…but on paper..
                Edited By ashley needham on 27/05/2016 18:46:44
                #65678
                Graeme Linskey
                  @graemelinskey75588
                  Hi Dave,
                  thanks for the Link but it is an out runner is a no go my boat is setup for an in runner and to change the mount is far to much hassle cutting the deck open etc.
                  I have spotted a 1050kv inrunner same can size mount it is a direct bolt in giving 2300 watts not that I need that much …my question is will a 1050kv motor be down on torque a lot on 3s or 4s compared to the 460kv that was linked or should I not worry about it ? as its in a TUG torque is what am after not a one that will have speed and no pull?
                  looked at the Caldecraft 900 but the specs don't look great dilemma!
                  Your thoughts?
                  Thanks for your input if I managed to find another speed 900 and ran it on 4s how do I work out what extra power it is doing over 3s? just add the voltage and up the amps to suit so a fully charged 4s at 16.6 volts a 1/4 more just add another 2 amps over the nominal 12v at 8 amps or does it not work that way? 16.6v x 10amps
                  =166 watts
                  Thanks
                  Graeme
                  #65679
                    Graeme
                    The Caldercraft 900 is not the same as the Speed 900 in that it spins at only half the speed on the same voltage.
                    It's largely speculation and opinion anyway, but I wouldn't personally fit an inrunner using direct drive to the prop – especially if torque is the main consideration. Speed is not the same thing as power – see my comments elsewhere about Ferrari F1 engines and quarry trucks.
                    The nice thing about advice, however, is that you are at liberty to ignore it! Good luck.
                    Dodgy Geezer 1
                      @dodgygeezer1
                      Posted by Dave Milbourn on 27/05/2016 23:24:13:
                      The value of advice can be difficult to quantify.
                      I have frequently seen situations where advice which later turned out to be well informed and accurate was ignored in favour of recommendations which were slapdash and incorrect, purely because the former came from internal sources and was free, while the latter came from an external consultancy and had been purchased at great cost. It was therefore assumed to be much more valuable – after all, £1.2m is a lot more money than nothing…
                      So, if Dave were to set up a little sideline charging 50p for each technical post he responds to…… devil
                      #65681
                        Graeme. Using a wattmeter on the setup is the only way to reliably see what extra power the motor is putting out.
                        ​For tug use you need good torque. What size/type prop are you using?
                        A 35mm outrunner of low (sub-900Kv) Kv would probably do…the motors in this size get longer as the Kv goes down, and the torque goes up …however, the only way to gauge this as a comparison to other motors and Kv`s is to see how big an air-prop it will turn (on the specs)
                        Amperages of 15-25 are quoted as operating currents for instance on a FUSION 700Kv 35mm outrunner, on 3s, so in theory anything between about 150 and 250 watts without splitting hairs BUT obviously this depends on how much effort the motor spends in turning the prop.
                        A 50mm prop, for instance, is unlikely to make this motor notice that there is a prop connected to it, and the current may only be 4A, but a 100mm 6 bladed prop may make the motor draw 40A and melt.
                        Ashley (usual disclaimer)
                        #65685
                          So, if Dave were to set up a little sideline charging 50p for each technical post he responds to…... devil
                          50p??? An extortionate rate! Talking of which…
                          A team from a very well-known firm of management consultants came to audit my little local area of HMC&E once. Their rate was, at the time (around 1995), £2000/team/day. They sent a spotty twenty-something audit junior to see my team. Unwisely he chose to start with me.
                          I was told he'd been seen 15 minutes later, standing outside the building, sobbing over a cigarette which he'd lit from the stub of the one before. I didn't get chance to confirm this because he never came back. I did, however, take the liberty of sending him a personal copy – with my compliments – of the Public Notice which covered the work which I was doing and which he was supposed to "audit".
                          I wonder if they sent us an invoice.
                          'Honi soit' etc
                            I remember many years ago being sent to an obscure office of HMC&E to help do an audit. Unwisely I chose as my first task to have a chat with a senior member of the team.
                            This kindly looking old gent reminded my of santa so I felt comfortable in choosing him for the first interview……how wrong could I have been!
                            Behind closed doors this kindly old gent became a raging banshee, uttering such outlandish profanities as I had never heard before even during my service in the navy.
                            Weeks later I received a snotty memo from him so I audited his tax affairs and he has been paying double ever since.
                            Isnt karma fun.
                            Edited By Paul T on 28/05/2016 17:15:09
                            #65690
                            Graeme Linskey
                              @graemelinskey75588
                              It is connected to a Graupner Schottel drive unit MK 2 which I think is a reduction 3:1 4 blade 66 mm prop Graupner say no more than 12v forward and 8v reverse after further reading that is to protect the servo from ripping itself to bits vectoring thrust….. but my servo is more than capable… so that gives me 2000 rpm approx at the prop but the unit can take 8000 rpm not that I want to drive it that hard but more pull would be nice.
                              Thanks
                              Graeme
                              #65691
                                In your dreams, Dr Dude. As a former HMRC employee I get an Income Tax Personal Allowance of £50,000 as well as a gold-plated, inflation-proof pension which I find embarrassingly difficult to spend.
                                Here is the nightmare – in duplicate (as are all things Civil Service)…enjoy!
                                  Graeme. This is a modest sized prop especially when the drive is running a 3:1 reduction. I cant see why a 900Kv 35mm brushless would not drive this adequately,,,,on 3s this would give an unloaded RPM of 9900 revs and with the reduction 3300….a useful percentage increase over the 2000rpm (unloaded) of a 900 motor ??
                                  ps ignore the rich kids…..
                                  #65698
                                    Graeme
                                    You may find this of interest. It certainly infers that the motor speed has to be carefully controlled if damage is to be avoided. That's critical as spares are increasingly hard to find for Graupner items. **LINK**
                                    BTW if there are any Mail readers out there I'm sorry to disappoint you but the tax and pension figures I quoted above are manifestly untrue…..but I can dream, can't I?
                                    Graeme Linskey
                                      @graemelinskey75588
                                      Dave,
                                      After reading that thread I think as you say it is down to motor control thrusting sideways flat out not good and as for the comment stripping out the bevel gears because the prop got jammed in weed well something has to give a blocked 900 pulling 54 amps again user control.
                                      The OP does have a point why recommend a 900 torque and limit you at 12v and that was an addendum by Graupner…. maybe they got back so many broken units they decided instead of retooling to make sure the drive was up to the job they covered there backs by a simple addendum.
                                      Maybe they have uprated the units apart from bottom metal gears they may have given extra support to the top as that post is over 5 years old my drives are a lot newer.
                                      So since I have 4 of these units I am going to mount one on a 10 mm piece of plywood hooked up a 1050kv motor on 6s which gives around 2300 watts and 24000 rpm 3:1 reduction is 8000 rpm which Graupner say is the max but they don't say loaded or unloaded….then wait and see what happens under load…..
                                      #65720
                                        Graeme
                                        On reading the thread I'm certain that the 8000RPM limit applies to the input speed and not the prop speed. You only have to read what the other owners are using. It seems that Graupner first mentioned supplying only 10v to their Speed 900BB, which equates to 5000RPM unloaded. If you really do believe that the Schottel unit – which is simply moulded plastic – will withstand over 3BHP then by all means do as you propose. I wouldn't want to be there when you do.
                                        Graeme Linskey
                                          @graemelinskey75588
                                          Your certain but not sure ? so you don't know ? u are assuming if it blows then I proved my point.
                                          I don't care not really just buy another ……..great unit no drag with rudders total 180 degree control it is an experiment
                                          got 4 spares no big deal
                                          have you ever used these units and what they can do ? I have proof is in the pudding
                                          and if it holds will you retract your statement
                                          #65722
                                          Graeme Linskey
                                            @graemelinskey75588
                                            your missing the point why did they restrict the unit to 12v and say you use a 900 torque which can take 40v its wrong
                                            #65725
                                              As I said, the nice thing about advice is that you're always free to ignore it, particularly if it doesn't square with the answer you were hoping to get. Good luck.
                                              Edited By Dave Milbourn on 30/05/2016 08:33:09
                                              #65726
                                              Charles Oates
                                                @charlesoates31738
                                                Light the blue touch paper, and stand well clear!
                                                #65732
                                                Graeme Linskey
                                                  @graemelinskey75588
                                                  watch out for parts flying over the uk! test bench is a go for tommorow!
                                                  #65798
                                                  Charles Oates
                                                    @charlesoates31738
                                                    Hi Graeme, how did the experiment go ?. I forgot to ask if your unit was well lubricated before the test.
                                                    Chas
