Graupner Motor
Graupner Motor
Home › Forums › Beginners › Graupner Motor
  • #14294
    MATTHEW CUTLER
      @matthewcutler34747
      Hi,
       Not sure which motor to go for,Graupner 700 turbo 9,6v or the 700bb turbo 8,4 v.
       Also could anyone tell me the maxium number of cells you can use with each is?
       Thanks
      #14305
        MATT. without  filling up valuable forum bytes with endless lists, the Cornwall model boats site lists a few Graupner motors or I dare say there must even be a Graupner website, which will have the definitive answer to things technical in it.. There is a bit of power and rev difference between these engines…what sort and size of boat are you building and what are you going to use it for…racing / personal amusement / must be faster than fred`s P.T boat ..???  Ashley
        #14306
        MATTHEW CUTLER
          @matthewcutler34747
          Thanks for your response.
          I have two projects, the first is an old super hawaii that will be used for amusement, the second an outrigger measuring just over 28" for more serious stuff.  You’ll have to excuse my ignorance but i was more concerned with what the 8,4 v and 9,6v reference really means. Although there are many sites detailing the output of each and somewhat conflicting information, none mention what the voltage difference really means in respect to run time etc?
           Also on may sites it tells me that the 700 will run up to 12v max, on the box the motor came in its says up to 14.4v?
           Many Thanks
           Matt
          #14307
            Matt, good point. I think the 8.4 or 9.6 is what the motor is designed to run at for optimum efficiency, I suspect their amp consumption at max efficiency is at this voltage. HOWEVER physically the motor will run at the other voltage 14.4 or whatnot. Obiously the power output will be better and the revs will be more at the higher voltage, but I suspect not neccessarily say, twice the 9.6 figure at say 18v. The run time really depends on how much the motor is loaded as well as what voltage you are running it at. An ammeter and a bunch or different props would be required at the pondside to get that max efficiency, but for max performance one suspects the max allowed voltage would be required.   Ashley.. there must be some fast boaters out there?? I am a slow boater personally.
            #1629
            MATTHEW CUTLER
              @matthewcutler34747
