Hi Robin,
Try this:
Open new Word document
Press enter, then type name in required font, press enter again. (the two enters are to give you black above and below the name).
Highlight this area by holding left mouse button down and dragging it down over it.
Click on “Format” at top of screen..
Click on Borders & Shading.
Click on colour black, then click OK.
That will give you the black background.
To change text to white, leave it highlighted and click on small arrow to right of “A” on top of screen. Select white colour and press OK.
Then you can print it out, white on black!
If you have a scanner, scan it back in as a jpeg. Then insert it into a new Word Document and you can shrink it as small as you wish. If you don’t have a scanner, take a photograph of it and use that to give you a jpeg.
