gears for electric motors? where to find those
Home › Forums › R/C & Accessories › gears for electric motors? where to find those
  • #44100
    Daniel Cardona 1
      @danielcardona1
      Hello to all
      I'm new in this forum and i'm a total noob regarding rc boats, but i'm a modeller and i build rc model aircraft but all of them are glow powered.
      so finally i got really interested to this new hobby ,so much that after buying some magazines.. two of them actually (rc model boats magazine of course) by luck maybe , the two magazine's had plans from the same designer, glynn guest. and all apear realtvely easy to build. the model that i want wish to built after a search through the net is the Miami crash boat by glynn guest.
      so to cut short , i noticed that the designer likes to use gear driven power setup, all the motors use a reduction gear box , one gear on the motor and the other for the shaft, by problem is , where to find thes type of gears, i tried e-bay but no avail maybe i'm doing something wrong. i was considering using a direct drive that for me is more simpler but looking to the plans it looks there i'snt much room
      any suggestions? or good sellers from e-bay wink? also they must be able to ship overseas. to Malta
      regards
      daniel
      #5267
      Daniel Cardona 1
        @danielcardona1
        #44101
          Daniel
          I believe Glynn uses these Graupner gears. **LINK**
          Cornwall Model Boats advertise a World Export Service so you should be able to order with confidence. I've always found their service superb.
          Edited By Dave Milbourn on 30/09/2013 12:32:40
          #44103
          Daniel Cardona 1
            @danielcardona1
            Posted by Dave Milbourn on 30/09/2013 12:31:53:
            Wow that's a fast reply, thank you so much Dave!
            May i ask you if you know what type of motor shaft dia must be used to these gears?
            Thanks Again
            kind regards
            Daniel
            Daniel
            #44104
              I'm afraid I've no more information than what is on the link. I suggest you E-Mail CMB and ask them – or maybe GG himself is watching from above………………
              Kimosubby Shipyards
                @kimosubbyshipyards
                Daniel – hello,
                try this supplier, they post world wide according to their home page too.
                I've used some of the gears myself with no complaints.  The gears are available for a range of shaft diameters, and they also provide shaft adapters for other sizes, for example 5mm down to 3.2mm etc.
                They also do some nice geared motors with inbuilt right-angled drives
                Kimosubby
                Edited By Kimosubby Shipyards on 30/09/2013 14:11:10
                #44112
                  That's a handy little site, Mr H. Many thanks.
                  Kimosubby Shipyards
                    @kimosubbyshipyards
                    Always try to oblige, Mr M.
                    Was in Rugby last Friday, didn't realise how close that was to you. Canal boat trip round the Warwickshire Ring.
                    Aye, kim
                    #44483
                    Kimosubby Shipyards
                      @kimosubbyshipyards
                      Daniel and Dave,
                      here's another site and newsletter for stuff for modellers including gears for motors etc. Rapid electronics.
                      Hope it works
                      Kim
                      #44486
                      Amy jane September
                        @amyjaneseptember49770
                        For those of us that don't like paying for things, discarded printers are a treasure trove of gears, drive belts ,springs and motors! (The stepping motors make great micro generators…)
                        #44504
                          Since Graupner have been going through their troubles, I look for available items and a dispiriting number seem to be "not available, no restock date". It could be that the new dynamic management have seen a different core market and lost interest in model boat builders. I hope not, but accountant driven companies have a tendency to fail moderately slowly without anybody apparently being to blame. At least, not in higher management.
                          The geared units were very convenient, useful, simple to use and compact. I hope they reappear. The alternative is direct drive, probably a different motor, and probably a different layout of things like batteries, servos, radio and ESC.
                          #44954
                          Haig
                            @haig
                            Does anyone make helical gears? Straight cut gears are unfortunately very noisy. I have tried all sorts of noise deadening and even boats that don't make much noise in the garage soon exhbit noisy characteristics on the water. I have tried Graupner, Robbe and Master airscrew and a few from other sources.
                            Gears with teeth cut at 45 deg would be much quieter. Surely some manufacturers have thought about this by now.
                            #44957
                            Keith Long
                              @keithlong89920
                              If you want helicals then HPC do them in steel, brass, tufnol and delrin. If you do use helicals you need to be aware that as well as a radial thrust on the gear there is also an axial load that needs to be catered for – the gearbox end plates might need to be a bit beefier. I have no connection with HPC but they have a good reputation for their products.
                              Keith
                              #44959
                              Haig
                                @haig
                                Thanks Keith & for the link,
                                I have had a brief look at their website. A huge range so I will need to do some careful measuring and a detailed study of what I need to replace some of my straight cut gears on my ships before placing an order as I am in Melbourne, Australia.
                                Haig
                                #44960
                                Keith Long
                                  @keithlong89920
                                  Hi Haig
                                  If you have a model shop near it might be worth looking to see what Tamiya do in spares or what is available for the rc cars, buggies and choppers. Not sure if the gears would be helical but they should be good quality especially if intended for use with ic engines rather than electric motors.
                                  Keith
                                  #44972
                                  Haig
                                    @haig
                                    Hi Keith,
                                    The boats / ships are all electric – there are pictures of some of them in my photo album, and the main issue is the noise reduction, hence my leaning towards the helical gears. I will give these HPC gears a go. Thanks again for the link.
                                    Haig
                                    #44975
                                      have you considered using toothed belts instead? Just about all gears have noise issue, particularly in a model boat hull which acts as an amplifying soundbox.
                                      Haig
                                        @haig
                                        Hi Colin,
                                        I have, and have seen some models using them, but they take more space in narrow hulls, and I am conscious of possible difficulties in getting replacements.
                                        My later models have plates soldered to the end of the prop shaft tubes and the motors fixed to them. Then the two gear wheels. There is no need for a coupling with this arrangement.
                                        Is there some measure of noise difference between a set of straight cut gears and helical gears? I may also ask a couple of experienced rotating machinery engineers at work for their opinion.
                                        Haig
                                        #44979
                                          Hi Haig,
                                          Yes, I appreciate there can be mounting problems when using belts. In a couple of my models the motors are actually mounted on the underside of the deck to get the room I needed! They are small models though.
                                          Haig
                                            @haig
                                            Colin, Keith,
                                            The general consensus is that the helical gears will be quieter than the straight cut ones, so I will get some and mount them. I will report on the findings. It may be the start of a new trend. Thanks to the MB forum & Keith in enabling me to obtain a supplier.
                                            There is also an Australian maufacturer of helical gears but the smallest bore is 6.35mm which is too big.
                                            I am currently building a 1/72 scale Z-39 WW2 destroyer and this will be a good ship to try them on.
                                            Haig
