GE-Keel
GE-Keel
Home › Forums › Beginners › GE-Keel
  • #11773
    Ducky
      @ducky
      Will be watching this project develop,as I only saw the Jeanie Deans in the background from about the midway stage of the build
      I’m sure its going to be a great learning curve for others just starting out in modelling as well as myself,as Bob’s boatyard is full of great models,(sails and electric)
      #11774
        Well thank you Peter……….Those are very nice encouraging words!
        I must say, I`m enjoying life at present
        Progress will not be as rapid and chaotic as usual…….with all you lot looking over my shoulder……..(I hope anyway)
        #11784
          Not had much feed back……..anybody out there following the project?
          #11786
          Len Ochiltree
            @lenochiltree67043
            Less of the chatting and more of the building!
            Merry Christmas Bob,
            Len
            #11787
              Hello there Len!……………………and a merry Christmas to you too
              Hope your following the build of the Great Eastern……..it won`t be a museum masterpiece……but it should look great when it`s finished
              Just sorting out the formers at present and trying out the first pair of planks
              Are you following the build?
              #11798
                Hi Bob
                Looking good so far but I am looking forward to the installation of the engines and seeing how you sort out the drives.
                Merry Christmas Bob
                Manxman
                  @manxman
                  My sentiment entirely Len – Get on with the build …. of course were watching Bob
                  Hope you and your family have a good Holiday (ok, you can have the day off – but just the one !)
                  Cheers – Ken
                  #11801
                    Thank you …….Ken Len Peter and Paul…………..Pleased that you are keeping up with the progress. The posting time lag is a pain……….all formers are glued in and the form has been checked with trial planks.
                    Cutting all that plywood has worn out my stock of cheap bandsaw blades!…….At the moment, the plank shop is out of action!
                    Wishing you all a Happy Cristmas chaps!
                    #11808
                    Don Koehler
                      @donkoehler51711
                      Hi Bob;
                        For every comment you get there are ten who remain silent but are watching.  I for one am looking forward to following the construction of Great Eastern.  I am the slowest modeller in creation and you will probably provide a wealth of information and building tips.
                        Looks good so far!
                      Cheers
                      Don
                      #11809
                        Hi Don………………Thanks for your comments………it`s nice to know there interested parties out there……..and some new faces too.
                        I may appear to work quickly……but when you consider I often put in 15 hour days….progress is inevitable
                        There are three planks a side on the hull now……but I`ve discovered I need to raise the hull off the work surface for access the the "Lacky clamps" This is no problem as the hull is quite rigid and easily moved about……..thanks the the main spine.
                        The plank shop will be open today
                        #1466
                        Ducky
                          @ducky
                          build project
