has anyone come across this phenomenon with the futaba transmitter/reciever
i ve set it up all ok esc has forward / reverse , servo works correctly and can be reversed if needc be
my concern is that i was under the impression that if i turned the transmitter OFF whilst reciever is ON ( to simulate loss of signal ) the motor would stop and .according to the instructions the rudder will revert to the neutral posision which i will do, but the motor either switches to reverse and reves furiously or stays at the setting it was at when signal is lost ie trans turned off.
i would have expected the system to shut everything down for saftey reasons, as it does with my planet t5 set
im pretty sure it can be made to perform this function but quess i m missing something to make it happen ?
any ideas gratefully recieved
rgds
