Fast Electric
Fast Electric
Home › Forums › All things floating › Fast Electric
  • #38440
    Steve Elsmore
      @steveelsmore
      Morning All,
      Have just bought a Pro boat Miss Geico, the boat came with a plastic prop – any ideas as to where to get metal props for these boats (as i normally do scale and this is my first lunatic boat)
      Many Thanks.
      #3938
      Steve Elsmore
        @steveelsmore
        metal prop
        #38443
          Steve, anything wrong with the plastic prop??
          In order to fit something else, you would need to properly identify the style and size of fitting.
          ie….4mm threaded, 5mm threaded, dog drive and if so in what size shaft. Some commercial boats have non-standard prop fittings, and these can be tricky if not impossible to replace the prop on.
          BUT there are loads of bods selling props, surf for Octura props, that will get you suppliers of fast props. You will need to know the form, pitch and diameter of that currently fitted, and whether it is a hydro or sub-surface.
          Steve Elsmore
            @steveelsmore
            Thanks Ashley,
            It's just that i was looking at the Pro Boat Stiletto as well and that has a metal prop.
            Steve.
