external safety loops for fast ic power
Home › Forums › R/C & Accessories › external safety loops for fast ic power
  • #43604
    captainslog
      @captainslog
      I am now in a position to continue with my 48" virgin challenger. This boat is going to be heavy and whilst not a racing boat will be producing quite a bit of torque and power. Therefore in an emergency will require a quick engine cut off in the way of an external loop. It is powered by an SC 60 marine glow with a large 3 blade brass prop. I have seen safety loops for electric powered cut off (easy enough) and petrol/gas also easy enough. but never for a glow engine. apart from attaching the end of the loop to the fuel line (disconnects from carb or filter) I cant see any other way to stop the motor. any ideas appreciated please
      thanks keith
      #5252
      captainslog
        @captainslog
        #43606
          Keith
          Look up SparkOut from DocandDave **LINK**
          #43610
          Telstar
            @telstar
            Keith Disconnectin the fuel line seems a bit drastic. Could you not incorperate a ON/OFF fuel valve similar to this **LINK** , this could be operated by a safety loop, or with an electronic safety circuit
            Cheers Tom
            Edited By Telstar on 08/09/2013 16:09:19
            #43611
            John Shire
              @johnshire55937
              Disconnecting the fuel line as a method of stopping the engine seems more like madness than drastic, what will happen when the free flowing fuel reaches the hot engine or exhaust? I am no expert but I assume that a loud bang followed by a fireball might be expected.
              John
              #43612
                The SparkOut only works for petrol engines but if anyone knows of a small, cheap 5v solenoid valve which we could adapt then there's no reason why it shouldn't work for glowplug motors (somehow ca't bring myself to call them "nitro" motors).
                captainslog
                  @captainslog
                  Interesting thoughts so far, paul I`ve seen a system for sparkout but as dave says that seems to be for petrol/gas with a spark plug. and lol at johns comment. yes john I realised that , which is why I asked for a possible solution. Telstars could be adapted I suppose, by attaching 1 end of the loop to the arm of the valve so that when it is pulled the fuel could be directed to a dump bottle in the hull.( loads of space for 1) This doesn`t seem to be straight forward as I thought. Surely there must be a system that the off shore racing boys use? they cant all be using gas engines. Or even for the smaller engined boys, I would have thought it was a requirement for insurance purposes to race. I dont know never taken an interest in the racing scene. I`ll have to troll my many mags somewhere someone would have explained it thanks all anyway
                  #43648
                    You will have to run over water at a frightening speed to use a fuel loop in an operational emergency. The only remote system I can envisage – apart from a solenoid valve in the fuel line – would be to use a servo disc, shaped as a cam, to squash the fuel line when signalled either by a failsafe state or via a second channel of the radio.
                      I've never been interested in either I/C or racing, but the simplest solution might be a switcher controling a fuel valve such that both a valid signal AND electrical power were needed to hold the valve open. No signal, switcher cuts, stop. No power, valve doesn't hold open, stop. Or have I missed something?
                      #43670
                        Malcolm
                        Essentially that's what we've been on about, but the main problem is finding a suitable solenoid valve. The failsafe unit we already have. **LINK**
                          Theres a bunch of candidates here – **LINK** – most will probably be unsuitable for controling fuel, but an infernal combustion engine needs air as well. Cut the air supply, the motor stops. The devices are generall normally closed, run on 12 volts and want about 1/4 amp to stay operated.
                          This was pointed out to me by a guy who had had a static diesel do a runaway – the automatic sump oil replenisher had overfilled and the thing was running on the sump oil that it was firing up past the piston rings. The answer was to shove his dust coat into the air intake and run away until it went quiet.
