ESCs & motors
ESCs & motors
Home › Forums › R/C & Accessories › ESCs & motors
  • #68437
    P. H. Stones
      @p-h-stones25207
      Installing two Mtroniks Viper 25s into a boat with two 600 motors was easy enough but getting them to work properly was not. Following the ESC instructions I removed one of the red wires and linked everything up only to find that one motor only operated and when I changed the ESCs over, the other motor worked but not the first. I am using a Y lead for connection to the receiver and have checked all wiring. Something's wrong somewhere but what?
      #5450
      P. H. Stones
        @p-h-stones25207
        Viper
        #68438
        Kev.W
          @kev-w
          So the same ESC works both motors, but the other ESC works neither?
          If so, have you tried each ESC on it's own, with both motors individually (takes the Y lead out of the equation).
          It sounds as if one ESC is faulty, it does happen.
          #68440
          P. H. Stones
            @p-h-stones25207
            Thanks Kip. I carried out your suggestion and found that both ESCs are fine so reinstated the Y lead and tried again. At first the same problem arose but I finally tracked the culprit down. It seems one of the two batteries was not producing sufficient power despite reading OK without a load. Once that had been changed the two motors ran well so I'm hopeful all is now operational. Next step is to sail the boat.
            Kind regards
            Paddy
