ESC setup
ESC setup
Home › Forums › R/C & Accessories › ESC setup
  • #5130
    Gary Wood 1
      @garywood1
      #31291
      Gary Wood 1
        @garywood1
        I have recently upgraded from a 27mhz tx/rx to a 2.4 ghz set, i have swapped the rx in my boat but now i cant seem to get the ESC to re-set and cant find the instructions!
        The esc is an Ansmann VR18T, can anyone help?
        #31292
        Paul Freshney
          @paulfreshney24971
          A check on the internet has revealed that it is identical to Mtroniks,  website: http://www.mtroniks.net. It is therefore an ‘own labelled’ controller manufactured by Mtroniks for Ansmann,  I should imagine, much the same as Howes in the UK do.
          If you check the Mtroniks website and find the equivalent, I am sure they will supply the instructions, or you may even be able to download them.
          Paul Freshney
          Editor.
          #31294
          Telstar
            @telstar
            #31310
            Gary Wood 1
              @garywood1
              Thanks a lot for your help, i seem to solved the issues that my esc/receiver were having with each other, i had looked at conrad.com but couldnt find any manual so cheers, i now have 2 (just in case i lose one!).
              Thanks Again
              Gary
