Engine HP and Prop Selection???
Home › Forums › Beginners › Engine HP and Prop Selection???
  • #27027
    Allan Russell
      @allanrussell11393
      I’m new to modelling!!!   have almost finished the hull of my baby bootlegger 2.24m x   0.45m  replica of a 1923 Speedboat.  The hull weight is 12kg and is designed to carry 45kg and draw 90mm. Resistance calcs show it reaching the plane at 3.5 Knots with 3.7 newtons total resistance. This seems very little???
      I am totally at a loss as to what engine and prop to use, as I can not find a model boat of the same proportions as mine to compare. And I want the thing to get up and boogy!!! Can someone please help?
      #1970
      Allan Russell
        @allanrussell11393
        Baby Bootlegger
        #27032
        Telstar
          @telstar
          Hi Alan     As someone that seems to like the numbers.
          From info on one version of Baby Bootlegger (off the internet), the full size boat was about 11m  and powered by a 300Hp V8 engine.
           This would make your model about 1/5 scale (if I can do the math)
          So using the scale cubed 300Hp  become 300/625,  about 1/2 Hp or about 360W
          This is at least a starting point for motor selection, I would be looking at brushless motors running on say 2 by 8cell nicads giving about 18v.
          Prop selection is a black art I am trying to come to terms with but there are so many different sizes and shapes I wouldn’t like to say.
          Hope to see photos of your model on the site
          cheers Tom
          #27049
          Allan Russell
            @allanrussell11393
            Hello Tom, thank’s for your interest. I’m more interested in a petrol engine and have noticed they go up to about 15hp. The price jumps accordingly!!!!!  There is one coming out soon according to a website in Australia, that is a 2 cyl, 10hp water cooled unit with clutch for A$680.00, which is excellent value. It apparently revs to 23,000rpm. I wonder if this will be enough to propel the bootlegger at high speed with the right prop?
            Cheers Allan
            #27050
            Charles Oates
              @charlesoates31738
              Hi Allan,
                             I ought to hesitate before saying that there’s something that’s never been done before, but a model speedboat 2.2 metres long! It’ certainly new to me and probably to most others as well. This might turn out to be one of those models where you will have to do the learning and tell us all what you find out.  Having said that some people do build large models and I hope someone will be able to give you some ideas.
                      It’s a fabulous project, the bootlegers were beautiful looking craft  and I look forward to seeing some pictures, especialy when its running.
               Charlie
              #27051
                There’s a dedicated notice board and a thriving membership from the Offshore Model Racing Association (OMRA) on the ModelboatMayhem forum. As your model seems most like the sort of models they race – certainly at the top end of the engine sizes – then I’d suggest posting your question on there to see if anyone can suggest a suitable engine and prop.
                I would imagine that 23000 RPM would require gearing down to avoid cavitation.
                Allan Russell
                  @allanrussell11393
                  Thank’s Charlie, I’ll certainly get some photos posted as soon as I can. In fact it may seem a bit of a silly question, but I can’t see how to post photo’s on this site? Can you help please?
                  Thank you also Dave, I’ll have a look at that website. And I agree that the revs will need stepping down substantially.
                  I’ll keep you posted on how I go with ModelboatMayhem, Cheers for now Allan.
                  #27071
                    Allan,
                    Re posting photos, have a look at the FAQ section – link on the left hand side of the page near the bottom which explains the options. I’m afraid you can’t insert photos directly into a post.
                    Allan Russell
                      @allanrussell11393
                      Thank’s Colin, cheers Al.
                      #27082
                        Hello Allan
                        I have been thinking about your engine/prop question and, if it were me I would fit a 75cc 4 stroke Briggs and Stratton petrol engine  linked to a home made 1/2in dia shaft and a 4in 3 blade prop.
                        The 4 stroke will rev slower than a 2 stroke so it won’t need gearing down and it will produce a better exhaust note ( made from copper and water cooled exhaust system)
                        A unit from a domestic lawn mower would be ideal as it has a clutch already fitted.
                        75cc is more than enough power to move your boat and the engine will also add a decent lump of ballast to help get the trim right.
                        Allan Russell
                          @allanrussell11393
                          Hello Paul, thank’s for your input. I’m assuming the Briggs and Stratton is air cooled? of which will pose a problem for my boat, as the motor is fully enclosed. We’re on the same wavelength with the prop though. I feel that a 4 inch prop will be about right if the revs are not excessive. I’ll try and add a picture of my design if I can work out how to do it, Cheers Allan.
                          #27100
                            Hello Allan
                            Yes the B&S unit is air cooled but can be adapted for water cooling by cutting off the cooling fins with a small grinder (or hacksaw) and then coiling a small bore copper tube around the cylinder jacket.
                            I would like to see your design
                            Allan Russell
                              @allanrussell11393
                              Hello All, the Bootlegger is finished except for 2 more coats of clear of which will go on within a week. Photo’s will follow after that and I must say I’m extremely happy with the result. Without the engine and all running gear she weighs 18kg all up and sits in the water exactly where the design predicted. The engine will be the 10hp, 2 cyl RCMK linked to a 3 blade 85mm prop. With everything aboard and allowing for ballast if required, she should weigh less than 30kg, resulting in an estimated top speed of over 100kmh. I got the figures from Dave Gerrs hull speed predictions.
                              All I need now if anyone can help is some deck fittings!  such as cowl vents, fairleads, and cleats. Bearing in mind the boat is 2.4m long, the fittings need to be proportionate in size??? Can anyone suggest where I might start to look for these in brass or stainless please?  Kind regards Allan Russell.
                              #28224
                              Allan Russell
                                @allanrussell11393
                                Hello All who may be interested?  The Baby Bootlegger is finished and photos are posted.
                                Engine and running gear next, but have to move house first. Hope you all like the design, cheers Allan Russell.
                                #28228
                                Len Ochiltree
                                  @lenochiltree67043
                                  Blimey Allan, if you had made it a bit bigger you could have driven it yourself.
                                  A lovely boat build and what a large workshop.
                                  Len.
                                  #28236
                                  Allan Russell
                                    @allanrussell11393
                                    Thank’s Len, unfortunately the workshop day’s are coming to an end as we are downsizing in retirement……………I’ve still got my toy though!!! Cheers Allan.
