Ellesmere model boat show
Home › Forums › All things floating › Ellesmere model boat show
  • #22254
      Can`t see the annual model boat show at Ellesmere Boat Museum mentioned anywhere?
      I`m thinking its off again?…………..after such a great comeback last March too!
        The Long Build
          @thelongbuild
          Not sure why you are thinking its off as the March show had nothing to do with the August show !!
          The Show in March was a completeley seperate event superbly re-introduced by The Ellesmere Port MBC , and was not connected to the main event which as per the last 4 years has been at the Conference centre at Birchwood  WA3 6AE , not to be confused with any other events which are running the same day !!  and is unlikely to change for the forceable future.
          I posted this some time back in the Events section , see link below..
          The Model Boat Convention 2009
          #22258
            TLB said…….”Not sure why you are thinking its off”
            Your opening line, infers that the show is still on then?……….So when is it on?
            Think we`ve got a crossed wire here!
              Check out the Shows and Events link on the left hand side of this page Bob!
                Colin…………….I have done……………Hence the initial posting
                #22263
                The Long Build
                  @thelongbuild
                  Double Click the Link  I attached to my Post.
                  If you are talking about The Model Boat Convention this has not been at the museam for over 4 years. and has been at the Birchwood Conference centre as per my earlier post.
                  There was the Epic show which is no longer running at the Epic centre and this has also now been moved to a seperate Location at Birchwood by A Model World.
                  The 2 events are completeley seperate and not connected in any way albeit only a Mile apart, entry to 1 does not give entry to the other.
                  The show is on the Agust Bank Holiday 29th & 30th.
                  #22264
                    Thanks chaps
                    What a shame………………I enjoyed the museum events!
                    The Long Build
                      @thelongbuild
                      It is the same show just a different location , sailing going on as well , all arranged by the same committee who originaly did the Museam show.   But All in one large room (apart from the sailing)
                      #22279
                      Ducky
                        @ducky
                        Hope that “A Model World ” turn up !!! they didn’t at the Colwyn Bay Club after booking for it
                        Ducky
                        #22283
                        The Long Build
                          @thelongbuild
                          Posted by Ducky on 28/07/2009 08:31:23:
                          Ducky
                          They have nothing to do with THE Model Boat Convention at the Birchwood Conference Centre.
                          #22289
                          Ducky
                            @ducky
                            GOOD ,I’m glad about that !
                            Ducky
