Electric motor ?
Electric motor ?
Home › Forums › All things floating › Electric motor ?
  • #3682
    phill d
      @philld
      boat motors
      #29366
      phill d
        @philld
        Hello fellow boaters
        New to the eletric bit about model boats.
        Not new to ic boats, and have dabbled a bit with electric but now i have a question.
        I have a 38 inch planning type hull model that i will be usung as a rescue boat for my i c stuff incase of emergency or breakdown etc, plus a bit of messing about on the river.
        What i want to know is what motor to use ?
        I have the coice of two motors in my vast collection of modelling stuff, both motors are in very good condition, and hardly used.
        1st motor is a MFA Barracuda. 6 to12 volt
        2nd motor is a Decaperm what i believe to be 12 volt .
        Now the MFA is twice the weight i know, but what is the best motor to use ?
        The Mfa can swing a 70mm x type prop, but im not sure whast the decaperm can swing and what revs that would do ?
        are both similar for power ? and knowing the decaperm is 2.75-1 reduction would that allow a big prop as well ?
        The battery will be a 12 volt 5amp sealed lead acid,
        what would give the best performance ?
        this below is the boat
        [IMG]http://i1183.photobucket.com/albums/x479/phillnjack4/model%20boats/DSCF2822xxxxxxxxxxxxxxxxxxxxxx.jpg[/IMG]
        if anyone knows what this boat realy is i would also like to know
        phill
