Dual Model Control
Dual Model Control
Home › Forums › R/C & Accessories › Dual Model Control
  • #66875
      Can anyone help with a query?
      I'm nearing the end of building a Graupner Bernhard Gruben and daughter boat. My testing so far has been carried out using a separate Tx for each boat.
      Is it possible to use a 2.4 ghz Tx bound to 2 Rx, one in each boat. Then use the LH stick for the Bernhard Gruben and the Rh stick for the daughter boat. This sounds easier to control than 2 Tx at the pond. I can just see me mixing the 2 Tx up and not understanding why one boat is heading straight for the bank.
      Or I am I missing something?
      Thanks
      Edited By Tim Cooper on 31/07/2016 21:10:17
      #5433
        #66876
          Tim,
          Yes, that should work OK but you might need to convert one of the sticks to self centring for throttle control. (The other should already be self centring)
            Thanks. Just need to save up for a Radio with enough spare channels for the other functions on the main boat.
            Guess it will have to be on the Xmas list!
