Hi All
I eventually bought an ARTR: an Our Lass II from Deans Marine. I bought a radio and receiver, bound them and connected evrything up (correctly, I believe) and switched on. The rudder just moved fully to the right then wouldn't move. I connected the servo just to (Turnighy) servo tester and get the same result. If if switch everything off and manually move the servo to a "centre" position and reconnect to the tester, it justs goes fully to the right then stops.
I just wanted to ask the experts before contacting Deans Marine. Do I have a faulty servo? Is it just not set up correctly? What should I do next? Thanks.
