DC Motors – Mobile Marine
Home › Forums › R/C & Accessories › DC Motors – Mobile Marine
  • #47990
    shipwright
      @shipwright
      Has anyone got the basic data on the T12 and T24 motors that are sold by Mobile Marine ? By basic data I mean No Load rpm, No Load current, Stall current – all parameters measured with nominal voltage applied to the motor terminals. I am assuming that the "12" and "24" in the motor titles refer to the nominal design voltage. Also the weight of these motors.
      #5299
      shipwright
        @shipwright
        Parameters for T12 & T24 ?
        #48025
        Paul Freshney
          @paulfreshney24971
          Have you asked Mobile Marine Models? If they cannot or won't supply that data, then I would suggest you don't buy them, since that sort of information is essential to make the correct choice for your model.
          Paul Freshney
          Editor.
          #48027
          shipwright
            @shipwright
            Paul,
            Thank you for responding. No I haven't contacted Mobile Marine – I thought I would try on this website first. I'm not in the market for motors at present but I use Mark Beard's Excel application and have expanded upon the list of motors for which he obtained the data (now got 87 on the "Motors" worksheet – though many of these may not be readily available or are too expensive for model boat constructors – Mark had 28 motors on his Worksheet). All of the motors are of the "brushed" type though there is no reason for excluding "brushless". For those wanting a relatively low operating rpm (say 2,000 rpm) and large torque (say 150 mNm) the choice is fairly limited particularly if you don't want a 1 kilogram motor of 70mm diameter ! Obviously you can match propeller to motor with a gearbox but that tends to be noisy and inefficient.
