Corvette Kit Difference?
Home › Forums › Building Kits › Corvette Kit Difference?
  • #48951
    stephen kelly 3
      @stephenkelly3
      hi folks, I have got a revell hmcs snowberry 1/72 scale and I am missing some parts,
      this model is now discontinued. SO I have contacted revell and they say cant get the parts,
      so I have been looking at the flower class corvette 1/72 scale and all parts on photo's seem to be same, it is same size scale and same lay out on deck, anyone know if the parts from this would do for the snowberry.
      stevie
      #6150
      stephen kelly 3
        @stephenkelly3
        #48953
        lnvisibleman
          @lnvisibleman
          Hi
          HMCS Snowberry was a flower so they must be suitable.
          Mike
          #48961
            Stephen. You are not quite clear here; Are you looking at ANOTHER plastic 1/72 Flower kit?? and wondering if the parts will fit??
            I thought that there was only the Matchbox kit, which has been reproduced by one or more makers since going out of production?? (someone correct me please
            As Mike says, if both are 1/72 scale then the parts should be ok to use.
            stephen kelly 3
              @stephenkelly3
              hi Ashley, I want to know if the vents from the revell flower corvette (still for sale ) will fit the revell flower snowberry ( now discontinued ) as the vents are missing. I would need to get hold of instructions to get part numbers to order from revell.
              stevie
              Edited By stephen kelly 3 on 19/05/2014 16:37:58
              #49017
              stephen kelly 3
                @stephenkelly3
                now sorted, they are same size
                stevie
                #49019
                Paul Freshney
                  @paulfreshney24971
                  These are phenomenally expensive, but DJ Parkins does aftermarket accessory packs.
                  http://www.djparkins.com/acatalog/Flower_Class_Corvette_-_Detail_Sets___Replacement_Fittings.html
                  Paul Freshney
