Can I ????
Can I ????
Home › Forums › R/C & Accessories › Can I ????
  • #5170
    Andy Hustler
      @andyhustler32076
      #34146
      Andy Hustler
        @andyhustler32076
        Can i use a graupner 400 on a 6" shaft to a brass 30 mm prop to power my future project a 1 metre narrow boat .
        Andy
        #34151
        shipwright
          @shipwright
          Hello Andy,
          I have no experience of narrow boats but I believe that they are relatively slow. The Graupner 400 does about 16,000 rpm on no load at 7.2 volts. I suspect that you need to look for a lower revving motor or use gearing/toothed belt to reduce the rpm. On your behalf I'll ask the forum – "What is a good propulsion setup for a 1 metre long narrow boat ?"
          #34154
          Andy Hustler
            @andyhustler32076
            Hi Ian thank you very much for the kind offer and as i have said many times before I am gratreful for any help and advice in fact the more the merrier . In the mean time i will have a shufty about and see what i can dig up .
            #34155
            Gareth Jones
              @garethjones79649
              Hi Andy,
              I think the answer to your question is yes you could use that combination, but it would not work very well. There are several Graupner 400 sized motors and they all do over 16000 rpm on no load at 7.2 volts. In reality with a 30 mm propeller immersed in the water the rpm they could achieve would be much lower, well away from the optimum speed with the result that the motor would get pretty hot. You could fit a gearbox or belt drive with something like a 4:1 speed reduction but they tend to be noisy and you would lose some power and efficiency and might not have the space to do it.
              My narrow boat is 1.06 metres long and weighs 8.3 kg. It has a Graupner Speed 500E motor (part number 1788) running on a 7.2 volt battery, driving a 40 mm 3 bladed propeller. Performance on the water is very realistic and if you do use full throttle it can manage greater than scale speed, although it takes a while to accelerate. The free running speed of this motor is 7200 rpm and with the prop in the water it achieves about 3000 rpm. I have tried the same motor in another application with a 30 mm prop and it achieved 4700 rpm which is actually a very good match, better than in the narrow boat. That would be my recommendation but there may well be other possible solutions.
              One point to be aware of is that motor manufacturers make lots of different motors which may be of similar overall size and designation but can have widely different characteristics. If you want to understand what combinations of motors, propellers and battery voltages work then you must be clear exactly which motor part number you are considering. There was a smilar question on another part of the forum a couple of days ago when someone asked for a motor recommendation for a particular model. Someone recommended 'a Johnson motor' which is virtually meaningless since Johnson make hundreds, if not thousands, of different electric motors.
              Gareth
              #34156
              Andy Hustler
                @andyhustler32076
                Gareth many thanks for the great advice . I wasnt sure to be honest it's just that i had these bits "knocking about " and thought that i could use them on the narrow boat . So it's back to the spares box with the motor and prop . Once again many thanks for the advice .
                Andy
                #34163
                  Andy. And this is only a personal view, If 30mm is a good prop size for your canal boat, the personally I would simply use the 400, as you have it already. Remeber it only does 16000 rpm on full throttle and does go slower on part throttle or you could use a 4.8V batt . Depends if you want to buy a second motor or not
                  30mm is quite small for a prop and at slow revs you are not going to get much oomph, canal boats being unweildly and (possibly) heavy ?? a bit more power in reserve I find is always handy.
                  If you had a 40mm prop, then of course the situation would be different and as suggested a larger low powered 500 sort would be required.
                  Andy Hustler
                    @andyhustler32076
                    Ashley . Many thanks for your advice and when i am ready i will most defiantly invest in these items but at the mo it's very much future plans as my E Boat is on hold at the mo due to batteries for my control box not being strong enough although they are all AA and brand new , they are Kodak Batteries that i have used in the past but just not strong enough to light the lights , so to speak . So next week it's off to Ikea or class Johnson . Ikea have a 10pk of AA for 99p but i think i may invest in duracell or rechargeable . I think it might be an idea to run as survey on batteries to see what comes out on top or see what is the most popular and reliable on the budget range .
                    Again many thanks for the advice
                    Andy
                    #34183
                      This is a lovely little motor http://www.mfacomodrills.com/motors/385ln.html and would be just the job in your narrow boat with a 3 or 4 blade scale prop (30mm) on 7.2v.
                      If you want a bit of power in reserve then try one of these 555 Mabuchis http://www.action-electronics.co.uk/pdfs/MOTORS02.pdf with a slightly larger prop on 6 or 7.2v.
                      For a transmitter I would recommend the "instant" type of rechargeable cells like these http://www.component-shop.co.uk/html/aa.html#IN2500AA A four-pack of the Vapex 2100mAH will cost little more than four AA Duracells and a plug-top charger maybe another fiver. I wouldn't use those budget "ten for a quid" batteries in any modelling application. They're OK for TV remotes, travel alarm clocks and torches but not where there's an expensive (and maybe dangerous) model depending on them.
                        Ah.. Dave is so right. The 385 is perhaps an oft overlooked motor. It is a fiesty little thing and I have them on several ships turning 40mm props on 6v no probs. On 12v and 30mm props they are really quite adequate for faster things.
                        At the risk of repeating myself, although 40mm sounds a bit big for a 385 I have had no problems, they dont even get warm, on 6v, and if they are being overloaded a bit it doesnt show and the current consumption remains miserly.
                        I always use rechargeables for my transmitters, and almost everything else. I have never been the one at the pond side whose tx batteries have failed them!
