Can anybody help
Can anybody help
Home › Forums › All things floating › Can anybody help
  • #80686
    Gary Brown 4
      @garybrown4
      Hi I am building a boat with a mate and we are looking at improving the operating time. Can anyone provide tips on what powerpacks to use to power 2 x 600 motors efficiently?
      #4559
      Gary Brown 4
        @garybrown4
        Wondering if anybody can advise on correct power packs to use
        #80687
          Gary
          The obvious answer is to increase the battery capacity but we need to know a lot more information first.
          What type of boat is it? How big is it? What size propellers do you have fitted/propose to fit? What voltage are you proposing to use? And finally, which brand of "600 motors" have you bought?
            The "600" says that the can size is a bit shorter than 6cm. Commonly they used to be called "540" motors being 54mm long, but some manufacturers decided to "simplify" things by rounding up. To know what it is going to do requires that we know a bit more about what is going on inside it. There might be more information on the label.
            You can make a boat run longer by fitting higher capacity batteries, but the downside is that they weigh more and will cause the boat to sit deeper in the water. Adding an extra cell or two in series to increase the voltage will make it go faster. There is the same consideration of extra weight, but add in the consideration that the motors and controls will need to be able to cope with the extra power.
            Type of boat is important – a tug needs a different type of power than a race boat. Both can be fitted with some kind of 600 motor, but they both need very different ones.
