Brushless motor expertise required
Home › Forums › R/C & Accessories › Brushless motor expertise required
  • #43858
    Hans Kuhn
      @hanskuhn
      Hi,
      I'm researching whether to go brushless for my next boat, and I have a question for the experts.
      I often see brushless motors described with a 'required' voltage, either with an absolute value, e.g.
      http://hobbyking.com/hobbyking/store/__28765__hexTronik_DT900_Brushless_Outrunner_900kv.html
      This is a 900kV motor with a 'required' voltage of 11.1V
      Or e.g.
      http://hobbyking.com/hobbyking/store/__18968__Turnigy_D2836_9_950KV_Brushless_Outrunner_Motor.html
      This is 950kV motor with voltage range of 7.4-14.8V.
      My question is, will these absolutely not work with a voltage lower than the specified range? If for example I wanted to run the first one on 7.2V NiMH?
      I'm looking at lower kV motors for a tug, it would have to run a 40mm 3 blade prop without strain.
      Thanks
      Hans
      Edited By Hans Kuhn on 19/09/2013 16:22:24
      #5260
      Hans Kuhn
        @hanskuhn
        #43879
          Hans. I would say that 7.2V would be fine. I am not sure why they specify the voltage ranges for instance 7.4-11.1 v…as opposed to "up to 11.1v" , All motors will run at lower voltages.
          Do you have a reason for wanting to use a brushless motor?? I am afraid there will not be that much expertise on this site as to the use of brushless motors for tugs…
          Hans Kuhn
            @hanskuhn
            Hi Ashley,
            It's definitley not common to use brushless on tugs, but there's such a large range of brushless motors and speed controllers available that I thought there must be a suitable combination that could be used. The key thing seems to me to get a low KV motor to keep the revs down, and a good speed controller with reverse and maybe some other programmable features like start force adjustment.
            I haven't made any decisions yet, so far I'm weighing up the options and costs and doing some research. I've only just started on the hull:
            Maybe someone can comment on my options for brushed drive – would it better to go for MFA type geared motors, or something like Graupner Speed 500 E motors? I need to install 2 motors.
            Thanks
            Hans
            #43917
              Hans
              As far as I understand it brushless speed controllers are not very capable of reversing, and brushless motors don't like running at the sort of low speeds you might want for manouvering a tug. I gather that some of the US-made ESCs are pretty good (e.g. Castle Creations) but they are hundreds of dollars apiece. Chinese ESCs are available at silly prices but their reliability and current-ratings are highly questionnable.
              If this is a twin model then your choice of brushed motors would be either geared motors e.g. the MFA Torpedo 500, or high-torque low-speed straight-drive motors such as the Mabuchi 555 (either running on 12 volts).
              The range of Speed motors – in a reduced form – is listed by the new Graupner/SJ company but quite what the availablility is just yet is uncertain. It's for sure, however, that neither the Speed 720 Torque nor Speed 900 are listed. Shame, as these were perfect motors for medium and large tugs. **LINK**
              The Speed 500E would be far too fast for a tug without gearing down (about 3:1).
              Edited By Dave Milbourn on 23/09/2013 14:58:02
              #43927
              Howard
                @howard79726
                Hans
                Check out the Mega Mig 650 from Puffin Models (www.puffinmodels.com) which might suit your application. Pricey at £33.95 a hit, although they claim it won't need gearing. John Emms is very helpful if you give him a call there.
                Howard
