Brushed motor specifications.
Home › Forums › R/C & Accessories › Brushed motor specifications.
  • #65515
    Jeremy
      @jeremy15845
      I am planning to use 2 MFA 280 size brushed motors for my RC conversion of the Amati Titanic. The motors run on 12-24v with a speed of 8,400 rpm at 12 v. Next size up in the MFA range is a 360 size motor which runs on 6-15v with a speed of 8,320 rpm at 12v. Go up to the 380, and ir runs on 3-7.2 v, with a maximum speed of 19,000 rpm at 7.2 v.
      I am using the 280 size because that is recommended in the conversion instructions and space is tight. However, I would like to understand why the smaller the motor, the higher the voltage required and what does it tell me about the power of the motor under load?
      I will be using two 6v SLA's in series to produce 12v, these batteries chosen because they will fit in the hull. The rest of the electronics will be Mtronics Marine 10 ESC's and a Mtronics W tail micro mixer (this model enabling the rudder to be controlled along with the mix in motor speeds). Space is at a premium and these units seem an OK match to the motors running on 12v. Will I be OK with these.
      Just a word of appreciation for the almost instant replies I get when posing questions on Model Boat forums. It is nice to know that there are so many experienced modellers willing to advise those of us less long in the tooth (in modelling terms, of course).
      #5425
      Jeremy
        @jeremy15845
        What do they mean?
        #65516
          Just a point re the batteries, I appreciate that these might be the best fit in the hull but there is a potential risk that their centre of gravity might be a bit high and a Titanic model needs the the C of G as low as possible with all that superstructure. It might be worth considering a couple of 6v NiMH flat cylindrical packs at sub C size which would really keep the weight down where you want it. Component Shop stock various capacities and they would probably be happy to make up a 12v pack for you if you ask.
            Jeremy. No idea why the different voltages, but MFA sell to industrial concerns so the voltage thing may be so that there is a wider application for machinery etc that uses a bigger voltage?
            I am a fan of the speed 280 motors , they are feisty little things that turn a 25mm prop with gusto. The "standard" 280 on 3v is a bit weedy.. I see from the MFA website that this produces 0.44 watts, the 12-24 one 1.66 watts. UNFORTUNTALY the Graupner speed 280 appears to be no more….but look at the J.Perkins distribution webthingy… Their EM100 is an up to 8.4V unit, 280 size and also looks feisty. Cheaper on your batteries…a standard 6-cell Nimh..just the job unless you NEED 12v for summat ??
