bow thruster esc that has same reverse speed as forward speed
Home › Forums › R/C & Accessories › bow thruster esc that has same reverse speed as forward speed
  • #67637
    eddie navarro
      @eddienavarro43642
      I'm looking for a esc to use on my bow thruster and need both forward and reverse the same amount of power both directions for turning left as right.
      #5441
      eddie navarro
        @eddienavarro43642
        bow thruster operation
        #67638
        Francis Macnaughton
          @francismacnaughton39461
          How about these
            https://www.mr-rcworld.co.uk/shop/variable-speed-controller-/
            Most mtronics ESCs are symetrical in output along with many others. Just avoid the ones that say things like "50 amps forward, 20 reverse".
            Or use a switcher or a servo with two micro switches.
            #67640
            Charles Oates
              @charlesoates31738
              Malcolm's suggestion of a servo and microswitches is simple, practical, and reliable. A friend of mine has been using this method for years without any problems.
              #67642
                The problem with using a switch is that the motor suddenly goes from stop to full speed. The paddles in some bow-thrusters are not very well secured to the motor spindle and we have seen several where they have detached because of this shock, usually rendering the thruster not repairable or even replaceable.
                If you want a decent ESC which will run at equal speeds in each direction and won't involve wondering about disconnecting the BEC then I suggest ACTion P79 (10A) or P81(5A).
