Yup, agree with Colin and Ashley
I've had this problem with a "Chinese" 2.4 set, the laughingly copied battery spring contacts (in the battery compartment) actually flattened first time a battery was pressed into place (alkaline), and the next time different batteries were used (enelope Ni-MH) there was no power as they made no contact.
lifting all the tabs enabled contact again, but as Ashley did, first I trimmed the slot to allow more positive end to poke through – and then I actually got some new spring contacts from Rapid electronics which are strongly springy and all is happy in the garden again.
Lesson – you get what you buy!
Kimmo
