Balsa Model Kits
Balsa Model Kits
Home › Forums › All things floating › Balsa Model Kits
  • #93582
    Peter Sykes
      @petersykes47234
      Does anyone much make Balsa Model Kits anymore??? I made loads as a kid and a few years ago I aquired a kit that I made of a Hydroplane / Tunnel hull boat. I can't remember the name (or what happened to the finished article). But I'd love to be able to build another one.
      Peter
      #4715
      Peter Sykes
        @petersykes47234
        #93585
          Hi Peter,
          Long gone are the Keilriv 7.jpg Kraft days, but J Perkins are distributing some new kits with ply keel, bulkheads & deck with balsa sheeting to the sides and bottom, they are around £60 for the wood kit, I built their review model Riviera Launch they are quite sweet
            A lot of the Glynn Guest plans use balsa as a construction material, with a lot of them available as free plans with Model Boats Magazine.
            #93593
            Peter Sykes
              @petersykes47234
              Posted by Ray Wood 2 on 04/02/2021 11:33:40:
              Hi Peter,
              Thanks Ray,
              I'll have a look at that.
              #93594
              Peter Sykes
                @petersykes47234
                Posted by Richard Simpson on 04/02/2021 11:38:54:
                hi Richard,
                Hi Richard,
                I've never built off a plan. Just too lazy and don't really have the facilities to cut out the bits.
                Peter
                #93596
                redpmg
                  @redpmg
                  Hi Peter,
                  SLEC also market a range of reasonably priced kits – mostly in Liiteply which would probably suit you . All laser cut and easy assembly as the parts fit very well. Most of the old Aerokit designs and more modern ones like Dave Milbournes Huntsman etc.
                  There is also the EeZeBilt site which has all the plans for the original Keil Kraft EeZeBilt boats and some later larger boats called 50+ which were mostly designed by the fellow who runs the site. Worth a look as they are all made of balsa and easy assembly with all the parts laid out for you . They are not plans as such – rather just parts drawings and assembly instructions – and they are all downloadable for free…………
                  There are also a few balsa kits from the US  – imagine they would be hard to find in the UK – and mostly hydroplane/racing types
                  Edited By redpmg on 04/02/2021 13:31:47
                  Edited By redpmg on 04/02/2021 13:33:26
                  #93617
                    Way back, balsa was the only game in town. Since then, we have seen various plastics, fibreglass, and ply become available, all of which do a better job, especially for any manufacturer hoping to sell more than one kit per customer.
                    Balsa can make great models, but working ones need a lot of work to be tough enough for use by modellers.
                    #93618
                    redpmg
                      @redpmg
                      Forgot to mention HA Kits
                      They market a line of reasonably priced models – believe mostly liteply again – but some parts may well be balsa. !
                      Still have balsa boats more than 30 years old which have survived many house moves with some very long distance travel included to UK and return to SA. – Glynn Guest also has a lot of old models too………………
                      #93620
                        As said above, an SLEC liteply kit is a good modern substitute for the old balsa type. However I think only the recent three smaller Faireys designed by Dave Milbourn use this material. The others use traditional birch ply.
