Ballast
Ballast
Home › Forums › All things floating › Ballast
  • #4265
    BRYAN ASTON
      @bryanaston57723
      Magnetic keel
      #61022
      BRYAN ASTON
        @bryanaston57723
        greetings all'
        I have just completed building the SY MEDEA overall weight is as the instructions
        On its maiden voyage this morning it ran perfectly in a straight line ,turning however was heart stopping experience, how it remained upright was.mystery, to me ,I believe the correct description is tender, are there any experts out there that have a plan for a removable keel, magnetic or mechanical, all suggestions would be very welcome
        The lake was dead calm
        Bryan
        #61023
        Martin Field 1
          @martinfield1
          Bryan, a chap on a different forum sent me details of his way of attaching a fin keel to one of his large square riggers.
          It involves the addition of a length of aluminium angle under the boat, to which the external, weighted keel is attached with machine screws. When on display, the external keel can be removed and the ally angle barely visible from usual angles.
          I hope that helps.
          Cheers,
          Martin
          #61024
            Hi Bryan,
            Somehow there is too much weight too high up in the model. My modified Medea is also the correct weight but is very stable and only a bit vulnerable to a stiff gust of wind which can push it over as far as the deck edge but it bounces back immediately.
            My batteries are cylindrical NmiH right in the bottom of the hull and the speed controller and R/X are also mounted low down alhough the motor is hung from the underside of the deck.
            BRYAN ASTON
              @bryanaston57723
              The 7.2v battery is on the bottom of the hull all electronic equipment is on the bottom ,the motor is halfway down the hull,nothing extra is in the superstructure . Lead shot is used as the ballast , it was tested in the bath and bounced back up when I held it right over until the decks were nearly awash, perhaps ,bearing in mind my previous experience with the Calypso when it capsized perhaps I am a bit apprehensive ,I will get some more lead shot.
              Martin
              If all else fails I may try the removable keel
              Thanks
              #61028
                You can ballast it down to just below the indicated waterline as this won't be noticeable when the model is sailing due to wave action and transparency of the water. Given the way the hull swells out from below this should give a useful amount of extra stability. Try an extra 5mm deeper, it could make quite a bit of difference.
                Andy Stoneman
                  @andystoneman15177
                  Hi Brian, The keel on my model is a long length of steel, its the barge yacht which was shown in the Model boats special edition. I found that a strong magnet allowed me to fix and move about when I wanted to a ballasted torpedo shaped weight attached to the fin, I did wonder if the magnet was strong enough and found it was more than capable of hanging on even with the odd bump on the bottom. I found that I had at first fixed my Ballasted torpedo weight too far aft which caused the model to stall when turning, so a quick adjustment sliding the ballast below the mast stopped the stall. Providing you have a strong enough magnet it should work fine.
                  Andy
                  #61043
                  BRYAN ASTON
                    @bryanaston57723
                    I will buy more lead shot today
                    Andy
                    I will search eBay for a strong magnet, to all watch this space.
                    Bryan
                    #61044
                    BRYAN ASTON
                      @bryanaston57723
                      Ps
                      There is a MEDEA on Model Boat Mayhem with sails, so there is hope.
                      Bryan
