Baitboat build
Baitboat build
Home Forums Beginners Baitboat build
  • #14061
    Darren Redshaw
      @darrenredshaw98238
      Hi I’m looking for ideas on how to do the electrics on a radio controlled bait boat, I have bought the hull complete with deck, hopper and weed guard. Would I need to ballast the boat?
      The boat is made of fibreglass, and is also black gelled for the waterproofing. I may need to fitt ribs in the boat to support the motor and possibly put another deck in support any other electrical bits.
      #14090
      Jake Knight
        @jakeknight71345
        hi darren
        i can give you any help you need about bait boats because i have built 2 of my own
        are you going to use the boat on a lake which can become  choppy?
        because if  you are you will need a bit of weight to the boat  and the best way to do this is to have a lead acid battery which are heavier than nicads and they have slow drain so the boat will not just die in the water because the battery has run out
        with the motor  you can just mount it on a small piece of wood  and glue it into the hull with epoxy resin
        i do advise to put a deck for electrics but also put them in a sealed container with a 1/4 hole for the electric wire to come out
        also do you know what electrics to use
        hpoe this helps and if you are unsure of anything please feel free to ask questions
        #1618
        Darren Redshaw
          @darrenredshaw98238
