AMPS out drive.
AMPS out drive.
Home › Forums › All things floating › AMPS out drive.
  • #4406
    Robert Putley
      @robertputley
      1970’s out drive for motors up to 20cc
      #70974
      Robert Putley
        @robertputley
        I have a problem with my AMPS out drive. However, I also have a new and unused one. One problem, the old has flat blade screws for the two oiling points. The replacement has Allen screws, and I do not have an Allen key to fit.
        Would anyone have an idea ofthe correct size Allen key? This is not mentioned in the instructions.
        #70978
          Robert. Assuming you have a metric set of Allen's, then presumably the screws must be an imperial size?? Having both sets is handy as sometimes a screw head gets worn and the next size up in metric/imperial will be a better fit. It is unlikely they used some really odd size screw.
          ​Ashley
          #70979
          Robert Putley
            @robertputley
            Do you think that would be a BANDIT size Ashley?
            #70982
              Robert . Not sure I am with you on this one///?? Ashley
              #70991
                Could be one of these be the Alan that you are looking for?
                #70999
                  Yes, the second from the left might fit….
                  #71003
                  Robert Putley
                    @robertputley
                    Ahh… Was using my ipad. Should have checked before sending the post.
                    Should have read..BA thread.
                    I live overseas now, so I would appreciate any suggestions as to where I could purchase these keys.
                    #71004
                      If it's a BA thread – which is highly likely – then it almost certainly requires an Imperial-sized Allen key. If you Google that you'll find plenty of UK suppliers. I'm sure one of them would post a small parcel like that overseas.
