Ammeter reading
Ammeter reading
Home › Forums › R/C & Accessories › Ammeter reading
  • #44906
    Empire Parkstone
      @empireparkstone
      Just fitted a wee ammeter twixt Batt and Esc flat out X 3 motors in the bath and showing around 25 amps .As the motors are each fused at 16A can I assume this Reading is the Sum of all 3 motors
      Thanks
      #5273
      Empire Parkstone
        @empireparkstone
        #44907
          If the ammeter is between the battery and everything else, it is reading the total load. If all 3 motors are running, yes, it is the sum of all three motors. Plus whatever is being powered off the battery. 25A for the lot indicates about 8-9 amps per motor.
          #44915
          Empire Parkstone
            @empireparkstone
            Thanks Martin I was hoping it was that
            #44920
              Empire.
              You may find that the actual sum total of amps consumed by the model is LESS when out of the confined space of the home test-tank (assuming you are not a millionaire and have a luxury sized test-tank), as the motors will rev out a bit more when the boat is going along and so the load is slightly less (if you were worried about being close to the ESC limit or whatever).
              Empire Parkstone
                @empireparkstone
                Thanks Ashley I did wonder about that due the considerable turbulance I'll try it in my Pond when I get time and confirm the readings
                #45011
                Empire Parkstone
                  @empireparkstone
                  Ashley as usual didn't quite grasp your ref to bigger water .I was thinking just the turbulence in a bath where in fact guess you meant the boat moving as opposed to holding it back .Anyway just tried a holding trial in my pond and of course same results as the bath enlightened Thanks again
                  #45024
                  shipwright
                    @shipwright
                    I constructed a new removable deck with a vertical wooden post. I strapped a voltmeter and ammeter to the post with a strong elastic band (there were holes in this new deck to enable the connections to the meters) and used a camera to video the meter readings – looked a bit strange but it worked !!
                    #45026
                      This low-priced little gizmo is small enough to fit into the model and will record maximum values of volts, amps and watts. I have a larger version of the same thing which will go up to 100A (from the same supplier),
                      **LINK** although the manual is not exactly crammed with detail!
                      Empire Parkstone
                        @empireparkstone
                        Ha! brilliant would be even easier with my wee one alternates twixt Volts and amps
                        Sory link no work   Pic in next post
                        Edited By Empire Parkstone on 14/11/2013 09:50:43
                        #45030
                        Empire Parkstone
                          @empireparkstone
