Align Motor
Align Motor
Home › Forums › Building Kits › Align Motor
  • #29392
    Uncle Albert
      @unclealbert
      Can anyone tell me the correct way to align the motor with the prop shaft is it with the naked eye or is there a tool you can purchase.
      Cheers
      #6029
      Uncle Albert
        @unclealbert
        MS Envoy
        #29393
          Hello Colin
          I always make an alignment tool.
          Use a length of brass or steel bar, the same length as the coupling assembly and drill each end in a lathe for the motor and prop shaft.
          If you don`t have a lathe, you could use the coupling as a last resort!
          Uncle Albert
            @unclealbert
            Hi Bob. Thanks for that but i dont have a lathe.
            Telstar
              @telstar
              Hi Colin
              This was discussed in a previous thread
              don’t know if this will help
              Tom
              #29418
              michael kemish
                @michaelkemish72883
                Hi Colin,
                I used a lenght of brass tubing, one end slips over the motor shaft, the other end slips over the prop shaft.
                If they (motor and prop shaft) are different sizes, you will find that one size of brass tubing will slip over the next size down. (and viceversa)
                So you might have to use a couple of short lengths of tub ing to achieve the desired result.
                Good Luck
                Mick
                #29419
                Armando Loni
                  @armandoloni78860
                  Colin – I usually align by eye – not the best method, but I always follow up by measuring the current drawn by the motor and minimising this by fine adjustment of the motor mount – you can also tell if it’s off-axis by the sound; if it’s a UJ coupling, you could also try making it straight and rigid by taping some lengths of metal sheet/rods around the perimeter – these can be removed once things have been aligned.
                  #29421
                  Uncle Albert
                    @unclealbert
                    Thanks everyone for your inputs.
