I would have expected a larger prop at that Kv for essentially a surface piercing design (as indicated by the instructions saying that the centreline of the prop should be lined up with the stern bottom)
My pontoon boat runs a massive x50 prop on a 28mm motor and it won’t run on anything smaller due to rampant cavitation. Bear in mind that with a 30mm prop on the bottom, only 15mm of it will be in the water at any one time.
Have seen several boats flounder because the props were unable to grip sufficient water to overcome the mass of the boat due to too small a prop and overspeeding.
Is the outboard as specified or is there no specific outboard specified (that’s a lot it specs)
