2.4 GHZ
2.4 GHZ
Home › Forums › All things floating › 2.4 GHZ
  • #26677
    Ted Gregg
      @tedgregg25215
      DOES ANYONE OUT THERE KNOW THE RANGE THESE TRANNYS WILL TRANSMIT . WE AT WINDERMERE SAILING ON THE LAKE HAVE A VAST EXPANSE OF WATER AVAILABLE ,WHAT IS CONSIDERED A SAFE DISTANCE ? AND ARE ALL MODEL 2.4  TRANNYS THE SAME WITH THE SAME RANGE
      #3563
      Ted Gregg
        @tedgregg25215
        RANGE
        #26686
        Len Ochiltree
          @lenochiltree67043
          If you can see your model then Tx will work it.
          Len.
          #26687
          Ted Gregg
            @tedgregg25215
            thanks len , rescue boat at the ready,just in case .
            does this apply to the cheap 2.4 sets with only two channels?
            #26694
            Peter Fitness
              @peterfitness34857
              I have one of the cheap (US$32) Hobby King 2.4 Ghz radios, although it has 6 channels, and its range is excellent. As Len said, if you can see the model the Tx will work it.
              Peter.
              Edited By Peter Fitness on 05/05/2010 23:01:49
              #26746
              Nigel Caddick
                @nigelcaddick15883
                I also have a cheapo Esky 6 channel 2.4ghz radio. It is so good I have bought 10 extra receivers for it and fitted them in all my boats. I have completely ditched 27 and 40 meg
                and have now just the one Tx for all.
                The range is excellent and I can control even my fast brushless powerboats nearly out of sight (And sometimes out of sight too )
                Most of the lads in our club are changing over and are buying the Planet radio which works very well, totally recommended (But not for Subs )
                ATB
                Nige
