Just received delivery of some 20mm and 10mm “strong” disc magnets. Some of which I need to hold an item on a boat.
My word, I had to use a knife to separate the 20mm ones and I struggled with that.
Fortunately they are not quite so strong on their own. Hoping epoxy is up to the job of holding them in place. I will (change of plans,) only use one 20mm magnet now instead of the projected three or four, on the boat and a 40mm penny washer of steel on the other item (fake fuel tank).
Sigh. Cut out the template for the perspex windscreen, cut said perspex, wrestled with a hot airgun and pipe to bend it ( not a bad job considering) to find it will not sit on the bow as of course there is a change in slope at the end so the rear corners of the screen do not touch the deck. Double checked the plan and it clearly shows the windscreen sitting on the deck which is impossible.
Just going to leave it as is and point out that the plan shape for the windscreen is incorrect….
