Thanks both.
The little Faun keeps throwing up challenges though. Having got the hull nicely shaped and smooth and the cloth and resin applied it was left overnight. Next morning the planks were found to have curled slightly from side to side giving the hull a thrupenny bit look! Sanded it but that basically just cut through the cloth.
So I gave the inside a good coat of Eze-Kote and will apply more later and made a stand so that I could work on the deck which brings me to the next thing. I keep looking at the hull and thinking that the freeboard isn’t enough, especially at the bow. On the real thing, as with many boats, the sheer kicks up at the bow and the deck is cambered. To facilitate easy building I straightened out the sheer and removed the camber, as per the Huntress which works well.
My drawing looks Ok but with the model it needs a bit more height. I’d got some 5mm bass sheet and so cut out another deck and that has been glued in place and I think looks Ok now. Not much, but on a small model it makes enough of a difference. To this I will add some mahogany and planking.
When I glued the second layer of planks on the Fisherman, using aliphatic and again 1.5mm thick bass, they also curved slightly and that was gluing fully to the first layer and along the edges, so I hope I don’t get the same problem. Maybe try epoxy resin instead and let the first coat dry and see what happens before applying the cloth? As I said, at least with longitudinal planking it looks like a planked hull!
Aliphatic seems to have this effect on planking as I had the same problem, albeit with very thin planks, when I did my decks. Must be due to the glue remaining liquid for longer as I didn’t have the problem when using superglue.
