Vic Smeed’s Silver Mist
  • This topic has 818 replies, 3 voices, and was last updated 13 minutes ago by Colin Bishop.
Viewing 25 posts - 776 through 800 (of 819 total)
  • #70786
      Hi Paul
      The shaft isn't actually bent, Doctor
      It has a short normal prop shaft and tube, glued into the hull and a longish extension, connecting the propshaft to the motor, further up the hull
      There is a flexible coupling connecting the two shafts together
      Because the flexible coupling could whirl, there is a bearing housing, close by
      For the maiden voyage, the bearing housing was not glued in position and could rattle about
      This is what made the engine noise
      The silencer I referred to, was simply me gluing the bearing housing to the hull
      Just my usual attention to detail, as friend Michael referred to!
      Capt Bob
        Captain Bob
        You will have to forgive me as this is probably a daft question but wouldn't it have been easier to fabricate (or buy) a single piece shaft.
          On the contrary,old chap
          Got plenty of propshafts and couplings in stock, Doc
          I liked the idea of the set up anyway
          Er……..How's your little kit build coming along now?
            The little kit is just fine but you know me I'm easily distracted by shiny things.
            #70794
              Hi Paul
              The shiny bent shaft you proffered could have worked actually, since the ends are just about in line…..ish
                For Geo and Kevin
                Made a start on the Ariel mast and assorted wiring
                For such a simple model, Vic has gone to town with the wire works for some reason, I like it though
                Note the mast folds down, to pass below the low bridges……….What low bridges?
                Just look at the size of that Flag pole!………All part of the model`s charm……….Total quirkiness
                It`s going to be a bit of a pain, getting inside, at the pondside?
                #70820
                  I try never to open my boats up at the pondside, that's when you tend to knock bits off!
                  Test before leaving home and check when you get back. I do have a syringe with a bit of tube to suck out any unwanted water through removable skylight or something similar though.
                    Good advice,Colin, but I was thinking more like getting the lead and batteries in and out
                      Captain Bob
                      Re; hinged mast and wires
                      Perhaps Vic imagined that Silver Mist might be moored somewhere upriver and needed the mast to collapse in order to get under a low bridge. The wires might be antenna for an early radio.
                        Fair point Bob, my boats are smaller and portable, I was overlooking the obvious!
                        Paul, you are probably right, low bridges can restrict where you could take this sort of boat unless you can reduce the air draught.
                          Old seafaring yarn……
                          I was mooching around Rockferry, last November, just as it was going dark, with a sea mist drifting across the mud flats, there was an old pub nearby, I could just make the lights shimmering in the haze and the faint sound of an old sea shanty, coming from within
                          Errrrr………No, this ain`t a Les Dawson joke
                          There was a hint of cigar smoke, wafting about, when I stumbled across an old anchor winch, half buried in the mud.
                          It was encrusted with the sands of time, and several old rivets embedded therein
                          Next day, I managed to drag the winch up the beach and after cleaning off the encrustations, I decided to mount it on Sea Mist……..Where it looks most befitting………I wonder where it came from?…..Mmmmmmm?
                          Just a bit of fun, me `arties
                          Edited By Bob Abell on 02/05/2017 17:42:59
                          #70846
                            You could grind corn with that Bob…..
                            mike farrell
                              @mikefarrell21522
                              Hi Bob sad to say but where is his pipe ?winkMichael
                              #70850
                                Hi Mike and Colin…….The question is……..Where did the winch come from?
                                It`s not a winch really, but it`ll do for Silver Mist
                                The story is full of clues
                                Banjoman
                                  @banjoman
                                  Hello Bob,
                                  That "winch" looks rather like summat that might once have been connected to some stationary toy steam engine or other … ?!
                                  Mattias
                                  Edited By Banjoman on 03/05/2017 06:20:02
                                  #70854
                                    Thank you, Banjo, for your comment
                                    The winch thingy was salvaged from my Great Eastern model in 2012 and I am quite pleased to see it being used again on Silver Mist, as an ornamental gadget
                                    It was part of the cable paying out mechanism, as seen on the BBC Coast GE cable laying episode
                                    The model was erroneously broken up in 2012, which I have regretted ever since
                                    The clues were aimed at other club members, who were involved in the epic story at the time
                                    The real Great Eastern was broken up at Rock Ferry, the pub of the same name was also broken up in the past few years, the river Mersey mud flats are full of old rivets from the ship and the cigar smoke was a hint towards Brunel
                                    Banjoman
                                      @banjoman
                                      Bob,
                                      Of course! I should have figured — I saw that episode of Coast when it was first broadcast, and ought to have remembered the cable laying mechanism.
                                      Mattias
                                      #70856
                                        Hi Bob
                                        As it was before I joined in on this forum, but why did you break up your famous model ? or am I missing something ?
                                          Ray
                                          I would like to send you a PM, but you don't seem to be accessible
                                          More info is required in your personal info box
                                          Banjoman
                                            @banjoman
                                            Bob,
                                            If you look underneath each post in the thread, you'll find a link there saying "Message member"; if you click that link under Ray's latest posting, you should get a blank PM form pre-addressed to him.
                                            Mattias
                                            #70859
                                              Hi Bob
                                              I've just sent you a PM to reply too, hope it works
                                                Bob Brunel
                                                Sorry old chap I didn't' realise we were playing guess the part, but well done in bringing the GE back into the conversation….are you sure you don't get royalties?
                                                Paul smile p
                                                #70864
                                                  Hi Paul
                                                  The gadget looks OK to me on the deck of Silver Mist as a winch and an explanation was necessary
                                                  There is no logical reason why the model GE story should ever be swept under the carpet and forgotten
                                                  Think about all the Kevin's out there who don't know about it
                                                    Bob Brunel
                                                    Having learnt so much from the last one you could build another one and show Kevin what its all about.
                                                    I am missing your patent riveting system but this time build the hull in sections for ease of transport.
                                                      Hi Paul
                                                      That would be an uphill battle these days, you do realise, I'm 80 now!
                                                      Looking back to 2007, the model only took 6 months to build
                                                      I was doing 15 hour shifts in those exciting days
                                                      It only had two 540 motors, 7 feet in length and yet it galloped about the lake
