You`ve done a great job there, Kimo
Soft solder would probably have been good enough, but silver soldering has really raised the stakes!…..Nice!
What size of thread are you talking about?
I`ll guess at about 5mm?
I`ll guess again and assume you are using stainless steel?
I`ll guess yet again and say you don`t possess a lathe?……Yep!
You will need a 5mm die and die holder. For stainless steel, you`ll need a quality die at about £15 to £20 …….The cheap ones from the handyman shops are simply not good enough!
The material will need a generous chamfer, about 1.5mm X 45 to start the thread off in a vice.
Hold the material vertically and apply a drop of oil, then press the die holder down onto the job, as you carefully rotate the die holder. Starting the thread is quite tricky at first! Make sure the die is square to the material. As the die begins the cut, don`t try and break the swarf coming from the cut, until you are sure the thread is being cut properly.
As you proceed down the thread, rotate the die backwards every few forward cutting rotations, to break the swarf and keep adding oil.
That`s about it really. If you can get away with using brass, then the task is easy, but some stainless is very tough to screw.
For the left hand thread, you will need a special die and that could be very expensive……..About £50.00 at a guess!
I would imagine that you could buy a length of LH threaded material and by using a brass coupling, you could silver solder the assembly?
Hope this lengthy description is OK for your requirements?
