Me again Paul,
you could always do what we are doing over here (some of us) and that's using the "Pollulu" chip systems and programming our own servo functions. My colleague displayed this at Warwick last year using the 4 servo board (retails at about £7) all you have to do is build it (solder) and then program it using free downloadable software compatible with Windows and Mac OX (and Linux). It's very simple, do not get put off by the phrase programmable chips! With the four servo unit he had a turret that turned, 3 guns that raised and lowered independently and noise and led flashes to resemble gun fire. And the unit once engaged continued with its movements free from the transmitter, for display purposes, or could be triggered to operate with the R/C when afloat if required.
As to increasing rotation, we have used piggy-backed servos. One hidden in the turret upside down, and its servo disc attached to another servo's disc, this one the right way up, or opposite the one above. The upper servo can travel say 60' each way, and it in turn can be rotated another 60' each way by the lower servo giving you 240' in total. Of course you need a bit of room, but turrets are light weight, so use mini/micro servos. The lower servo is slotted into a servo box very similar to that suggested by DM on another thread here last week.
Try and ovoid belt and gear drives, they need aligning carefully and will always let you down at some time.
Aye, Kim
