Hi Ray,
You won't believe the number of hours I have spent pondering this issue! I think I now know what to do, we'll see.
In my Fisher 34 album there is a photo on the second last row showing the innards of the aft hull section. Here you can see the mainsheet pulley in the centre just forward of the mizzen mast support hole. A little further aft (to the left in the photo!) you can see, both port and starbord, two more pulleys. These are for the 2 individual genoa winches. Each winch can pull in/let out about 45cm of sheet length. The winches are moved independentlyof each other. Obviously the leeside winch has to be slackened off as the windward side (to weather) is pulled inn. In theory the clew of the genoa should be able to move through 40-45 cm. This should allow a reasonble amount of genoa adjustment.
A little elastic cord here and there should help to absorb any inadvertant assimetric hauling of sheets. Both winches can be let out to enable the genoa to open up a bit for running with the wind or at least with wind abaft the beam. The Fisher is not known for it's sailing performance and this model will be tru to scale I'm sure.
Hmmm…. bet there'll be some of comments on this. Probably, everybody else who has a yacht already knows all this and have forgotten to tell me! Hope nobody reads this!
I have just opened a new thead for the Comtesse too. I suggested earlier that they would be under 'build blog' but they ended up as 'scratch builds' and 'kit builds'.
George
Edited By George Edward Connery on 07/05/2020 19:37:05
