Steering with twin screws
Home Forums All things floating Steering with twin screws
Viewing 25 posts - 1 through 25 (of 26 total)
  • #18828
    ArneS
      @arnes
      Apologies if this is in the wrong section but it was the closest I could find.
      My next model has twin independent screws but no rudder(s).  It could be sailed with two separate ESC and operated by either;
      1) using two throttle sticks operated in tracklaying vehicle fashion
      2) electronic mixing of rudder and throttle stick to give steering and propulsion.
      I know the principles behind the two methods. Could anyone with experience of both methods comment on their relative merits?
      ArneS
      #3305
      ArneS
        @arnes
        #18831
          The “Tank” steering method with one motor on each stick will obviously be a option but the latest mixer method using something like the ACTion ranege http://www.action-electronics.co.uk/mixers.php might be best. If you give Dave Milbourn at ACTion a ring he will be pleased to give some very practical advice.
          Pierre
            @pierre
            I used “Tank Steering” on a pusher tug which made it extremely manoeuvrable. I have a JR 6 channel transmitter, 40 Mhz, which was originally designed for aircraft. Careful reading of the manual produced an option called “Delta Wing” which exactly simulates Tank Steering without the use of extra mixers. Full ahead or astern used both motors, left/right on the right stick progressively slowed/stopped/reversed the relevant motor.
             I eventually disabled this option and installed rudders as when towing something heavy one effectively lost the power of one motor when trying to turn!
            Cheers – Pierre
            #18885
            ArneS
              @arnes
              Thank you Colin and Pierre,
              With only two responses I guess that this is an area of modelling in which few have experimented.
              Buying a mixer would be extravagant as my transmitter aready has this function.
              I guess the only thing to do is try both methods and see which is most comfortable.
              Thanks again, ArneS
              #18914
              Ducky
                @ducky
                 Hi ArneS
                My wife has been sailing her Wyeforce Tug with two props and two ESC’s for the last two years and she doesn’t use the rudder much and the boat can turn in its own length ! The turning wasn’t very good when I first built the boat and only used one ESC for both motors,but after she complained I fitted the second ESC and you wouldn’t believe the differance. Her indoors is happy as well so can’t be bad, she also has a rescue service attachment for the tug to save getting the main rescue boat out
                See my Album for tug picture.
                Ducky
                #18916
                ArneS
                  @arnes
                  Alas Mr “Ducky”
                  Your post does not help me with my query as to the pros and cons of using twin independent screws with either two throttle sticks or rudder/throttle mixing.
                  Your pictures are nice nevertheless
                  ArneS
                  #19017
                    Please try this link:
                    I think it may answer most of your questions. If you choose the last unit mentioned (P94) then you can set it to do either “tank steering” or rudder/motor mix, so you could choose which you prefer simply by flicking two small DIL switches.
                    It works for many folk (300+ sold already), but suit yourself – it’s a wide world.
                    ArneS
                      @arnes
                      Mr Milbourn,
                      Thank you for your response to my enquiry Edited by Moderator ArneS
                      #19083
                        Hi Dave
                        I have just spent a very happy hour wandering through your website and adding item after item to my “wishlist” its a shame that I have limited funds and have to recycle my motors and escs as I would be very happy to spend £100s with you.
                        Do you manufacture a V8 petrol engine sound generator as I would love to fit one into my barrel back speedboat. (I am looking for the V8 roar with the underwater exhaust sound)
                        Was it your goodself that I had a long chat with at Birchwood last year?
                          Hello Paul
                          The chap in our club has managed to fit a nice sound generator to his Brushless motor powered Aqua Riva………….and it has a nice effect
                          Ducky
                            @ducky
                             Hi Paul
                            The sound generator that Bob has just mentioned is a V8 engine that you wanted I will ask the chap thats got it,whats the make and get back to you.
                            Will look out for you at Ellesmere !
                            Ducky
                            #19116
                              Hello Bob & Ducky
                              Thanks for telling me about your chum with the sound unit and I hope that he is able to tell you what the unit is.
                              Meanwhile I hope to stumble across some on line friends at Ellesmere.
                              Ducky
                                @ducky
                                 Hi Paul
                                Got an answer for you on the V8 engine sound,
                                 “The sound unit is an Admiralty Electronics from Westbourne Model Supplies.” and the chap with the motor launch I mentioned says ;
                                “We might see you at Ellesmere” his name is Graham and if I see him there I will bring him over to speak to you Paul.
                                Graham is a Master Builder from the Sandbach area and a member of our club, his “LILY” a Windermere Steamer is something to see.
                                Will be looking out for you and Bob the Builder
                                Ducky
                                #19125
                                  Hey  Duckie
                                  An idea……..I wonder if Graham fancies giving a talk to Paul`s Model Boat Club, afterall, Graham has put a lot of work into his presentation?
                                  Worth a thought?
                                  ArneS
                                    @arnes
                                    Returning this thread to its original topic.
                                    I have tried the model out using mixed and track-laying types of control.  Both seem unusual at first, after a few minutes it felt easier.
                                    Not a lot to choose between these methods of control.  Sailing around the lake with the mixed throttles may be easier.  The two throttle stick method feels better when trying to sail a complex course at slow speed.
                                    Has anyone else had this experience?
                                    Edited by Moderator
                                    ArneS
                                    #19127
                                      I have tried to get the best of both worlds with my present model which uses a Futaba 6EXA Tx/Rx. combination.
                                      I have used the toggle switchon the TX which is intended for or lowering and raising the undercarriage on a plane to trigger a switch attached to the corresponding receiver channel which is used to switch the speed controller outputs between being on one channel or separate ones.
                                      This means that when sailing around the pond both controllers are on one stick but when get to a complex bit I can simply flick the switch to go into tank steering mode. The model isn’t finished but it works OK in the bath anyway!
                                      ArneS
                                        @arnes
                                        What a great idea Colin!
                                        It sounds like the perfect solution to easy sailing but still having that extra steering when needed.
                                        Not sure how you would switch from having both controllers on one channel to having them on two channels.  Do you physically switch the signal lead from receiver output to the other or is it done by using a computer transmitter?
                                        Thanks, ArneS
                                        #19134
                                          ArneS,
                                          I have put up an Album showing how it is done. If you have any questions just ask.
                                          ArneS
                                            @arnes
                                            Thank you Colin,
                                            Your post explains it perfectly. I would have worried about the monentary loss of signal to the speed controllers whilst switching over but perhaps it is no worse than the occasional “glich”.
                                            This is what a hobby forum is all about.
                                            ArneS
                                            #19163
                                              To blow Daves trumpet this link is well worth looking at
                                              http://www.modelboatmayhem.co.uk/Common/Electrics/Twin_motors.htm
                                              Sorry its MBM but needs must.
                                              Pierre
                                                @pierre
                                                May I also thank Colin – that circuit is a gem! Gone straight into my “Really, really useful” folder.
                                                Pierre
                                                #19174
                                                ArneS
                                                  @arnes
                                                  Mr Fat Controller,
                                                  Edited by Moderator I prefer Colins solution.
                                                  ArneS
                                                  #19187
                                                    Topic cleaned up.
                                                    Gentlemen,
                                                    I had hoped that the tit for tat exchanges would have ceased but clearly some of you were determined to continue. They do not reflect well on the Forum and so I have deleted all irrelevant posts and edited a few more. If you wish to continue the argument then please do so by personal message. All further posts on this thread should be constructive and on topic.
                                                    Thank you.
                                                      Subsequent irrelevant posts have also been deleted as I promised. I have sent ArneS a personal message concerning his postings.
                                                      Future postings not relevant to the subject matter or which contain personal or offensive comments by any member will in future be deleted without any further discussion.
