Hi Graham
I have the plans on PDF and may be one day build another, but, 25% bigger !!!
Too dam small for my fingers !!!
I ran the Hornet with a 3 blade 30mm CNC prop today.
First pickup to 1/3 throttle was better, but, top end speed down about 5KPH.
I ran my Precedent Huntsman topless today(no cabin).
I was not planning to run it, but, a ballast check for the battery position .
But, the boys said give her a crack!!!
First run the bow was sitting up to much, so I moved the battery forward.
Second run, right on the money!!!
The boat sat level and turned very well !!!!
Only running the 3648-1450kv on 3S with my go to 2 blade 40mm prop.
Harry Smith
Senior- In- Retirement.
