motor and speed controller trouble
Home › Forums › R/C & Accessories › motor and speed controller trouble
Viewing 25 posts - 1 through 25 (of 31 total)
  • #20046
    Queequeg Quint
      @queequegquint38270
      I have a 35 inch model lobster boat hull.  Motor is MFA Como 540 Torpedo with 2.5:1 gear reduction.  Electronic speed controller is Mtroniks 15 marine.  Battery is 12 volt with 12AH.  Propeller is 45mm in diamater, 4-blade brass prop.
      Here’s the trouble.  When I go forward, the motor stutters alot.  Sounds like it’s going on and off rapidly.  This happens at all speeds.  When I go reverse, the stuttering is much less, motor runs more smoothly.  But it stil isn’t perfect.  This happens in the water, or on the workbench.
      I put gear grease on the metal gears hoping that would solve the problem. That solved the problem for a while.  But then after I ran it in the water for about 30 minutes, the stuttering came back.
      I don’t know what the problem is.  Not sure is some water splashed into the motor, maybe that’s the problem.
      Any advice would be helpful!!
      Queequeg
      #5032
      Queequeg Quint
        @queequegquint38270
        #20049
        60watt
          @60watt
          Unless you mean the deleted Como Drills RE540/2  there is probably nothing faulty other than  the 540 is too much for the Marine 15 esc.
          A power choke rated at 100uH, 10 amp might solve the problem by smoothing out the current drain.
          #20050
          Queequeg Quint
            @queequegquint38270
            It is the MFA Como Drills RE540/1 (Torpedo 500).
            Is there another ESC that might work well with this motor?
            I’m thinking about the FR15 by a company called Electronize.
            Thanks
            #20051
            60watt
              @60watt
              I gave a £1 remedy to what I think is the likely problem.An email to Tony of Mtroniks might get you more info.
              Myself,I would change the motor rather than the esc but I wouldn’t do that either.I’d try a choke.Toroids are available from Maplins and in any old radio or computer equipment,enammelled copper wire can be obtained from transformers.If you don’t know the background then trial and error will sort it.
              Good luck
              #20060
              Queequeg Quint
                @queequegquint38270
                When you say the 540 is too much for the Marine 15 esc, do you mean that the esc doesn’t have a high enough amp rating?
                #20068
                60watt
                  @60watt
                  If your motor is not boiling hot after two minutes on twelve volts the average current will be below 10 amps.
                   A low inductance DC motor,pulsed at low frequency,has current surges on a par with the stall current. If you can’t change the esc frequency you can add a series inductance to smooth out the current demand to a flat,average value.
                  #20071
                  Telstar
                    @telstar
                    Hi A different look at the problem,  do you have any form of suppression on the motor?  is the radio equipment close to the motor?
                    Interferance from the motor brushgear sparking can cause problems.
                    Just a thought   Tom
                    #20075
                    Queequeg Quint
                      @queequegquint38270
                      Thanks.  Here’s a video I took.  You can hear how the motor sounds.  It was hard to hold the camera and the radio so that’s why the picture is so unsteady.
                      The motor does have complete supression.  I also moved the radio reciever far away from the motor.  I put some gear grease on the metal gears, and that solved the problem but only for a while.  In fact, after I put gear grease on, it ran perfect.  I ran boat for about 30 minutes, then it started stuttering again.
                      Also, the motor does not get too hot.  Just a little warm.
                      I really don’t know much about “series inductance” or a choke and toroid.  So, if a different ESC would solve the problem, I would go that route.  I like the motor (when it works) so I would like to keep that.  Unless maybe the motor itself could be defective???
                      Here’s the link to the video.
                      There’s a few other youtube videos by “OrcaBoat3” that were taken when the boat was working perfect.  This link is a video of when it is stuttering a lot:
                      #20079
                      60watt
                        @60watt
                        Motor sounds fine to me.The high pitched whine suggests it is happy.
                        That and the moderate temperature tells me you could go down to six volts and fit a bigger prop to compensate.That will halve the stall current.
                        The esc is OK too it just won’t tolerate your kooky arrangement .
                        I guessed you fitted 3 capacitors to the motor.The two capacitors to the motor case don’t filter out anything unless you lead a wire back to the supply negative.Better still,connect that to the water via metal fitting.
                        #20080
                        Queequeg Quint
                          @queequegquint38270
                          Thank you.
                          Yes, the motor has 3 capacitors which came attached in the fashion you mention.  Unfortunatley, I cannot put a larger prop on the boat becuase there is not enough space.
                          So, if I understand you correctly:  To make everything happy, (and I keep the motor, 12 volt battery, and prop) then I change the ESC to a higer aperage?  Mtroniks makes ESCs at 15amps, 20amps, 25 amps, and 40 amps.
                          If you have any better ESC reccommendataions, let me know!!  Thanks.
                          #20081
                          60watt
                            @60watt
                            The fact you have a gearbox and the motor is in the high audio frequency and motor temperature tells me your average current is low.Your peak current is high because the esc is a low frequency type driving a low inductance motor.The addition of a choke will smooth out the peaks.
                            #20084
                            Queequeg Quint
                              @queequegquint38270
                              Thanks.  Can you tell me how to install a choke?
                              #20087
                              60watt
                                @60watt
                                It is just an extra 12 inches of  wire in series with the motor.Break open one of the esc to motor cables.
                                 You wind about 10 to 40 turns of 1mm square (=10 amp) enameled copper wire round a Nickel Manganese or powdered iron toroid.That should give a 10 to 100uH inductor.The formers that fit over USB and peripheral dc power cables are ideal.
                                  I’m not even going to mention saturation….oops
                                #20095
                                Queequeg Quint
                                  @queequegquint38270
                                  All this sound very complicated and difficult.  Do you think that a different ESC would solve the problem altogether.  And if so, what one would you reccommend?  Thanks so much for your time!!!
                                  #20101
                                  60watt
                                    @60watt
                                    I sent you a message of where and what to get but this case only calls for a 50p Nickel Manganese ring core.Do you live near a Maplin or R.S. counter?
                                    P.S.
                                    Maplin do free delivery till Tuesday but ,honestly, it is a 20p ring core
                                    Edited By 60watt on 10/04/2009 09:03:30
                                    #20175
                                      It’s more usual to use a 6v supply through that motor and gearbox, especially with a prop of the size you have fitted. The 6:1 combo is generally recognised as the 12v one.
                                      MFA quote a typical current draw of 2.8A for this motor, so you should not require anything more than a 15A ESC – if that.
                                      A 6:1 Torpedo ran very nicely on 12v through an ACTion Condor 20A ESC in my Envoy (I just happened to have one spare), and that’s a big brass prop and moved a lot of water. Nothing got remotely warm and certainly the motor didn’t stutter.
                                      There are other manufacturers of electronic speed controllers than MTroniks and Electronize, you know
                                      Queequeg Quint
                                        @queequegquint38270
                                        Problem solved!  (I think…)  I loaded the gear box with petroleum jelly.  That took away the stuttering.  Somehow, the metal gears (which are bolted drectly to the motor), cause some kind of electic interference.  I pulled the motor out and held it far away from the receiver.  But it still stuttered.  Upon loading it with grease, the stuttering went away.
                                        Anyone ever have that problem before???
                                        #20854
                                        Queequeg Quint
                                          @queequegquint38270
                                          #20856
                                          60watt
                                            @60watt
                                            All the time,but don’t blame the gears.
                                            #21007
                                            Queequeg Quint
                                              @queequegquint38270
                                              Well, the stuttering came back.  So….  I did an experiment.  I put 3 more capacitors on the motor (for suppression), and the stuttering was substantially reduced.  Then, I put  another 3 capacitors on the motor.  Stuttering is now eliminated.  I ran the boat for over one hour and it ran perfect.  So, I have a total of 9 capacitors on the motor!!!!  Is this OK???
                                              What exactly do the capacitors do??
                                              One thing, after running the boat full throttle for almost an hour, the motor was very very hot.  But not hotter than any motors I’ve used before on RC cars.
                                              The other thing, full throttle didn’t seem as fast as before I put on the other 6 capacitors, but it seemed only a little bit slower.
                                              #21009
                                              60watt
                                                @60watt
                                                You are doing exactly the same job as the choke by adding high value capacitors.You are not adding rf suppression but you are filtering very high current switching spikes which causes the esc to shut down.That is why I suggested to contact the manufacturer to say if the 15 amp one is suitable for a geared 540 on 12.He could tell you if he has tested his esc on that with success.
                                                You could have got a single 1uF polyester capacitor and soldered it between the brushes. Forget about putting any more from terminals to the case.
                                                The grease helps by lubricating the gears.
                                                Where do you see sparks other than on the motor brushes? Certainly not on the gears.
                                                #21018
                                                Queequeg Quint
                                                  @queequegquint38270
                                                  Now a new problem.  Yesterday, the boat ran fine.  Full throttle for almost an hour!  Motor was a bit hot, but not too hot.
                                                  Anyway, I recharged the battery (12V, 12AH) overnight with a charger that switches to trickle when it’s fully charged.
                                                  Today, I ran the boat.  Everything looked and sounded great.  But after about 20 minutes, my full throttle got quite a bit slower.
                                                  I brought the boat in.  Opened the hood and I could feel the heat coming off the motor and it smelled like it was burning!  I wet my finger and touched the motor and the water boiled away right before my eyes!
                                                  Speed control was nice and cool.  (it’s now Mtroniks Viper Marine 20 amp… I accidently ruined the 15 amp one…don’t ask me how but I killed it)
                                                  So, something has happened between yesterday and today that has caused the motor to get super hot.
                                                  -Maybe something wrong with the battery?  the motor?  could the extra capacitors be messing it up?  oh man!!!!
                                                  #21021
                                                  60watt
                                                    @60watt
                                                    Plenty of info but the other information listed below would help.
                                                    What kind of capacitors were they? A capacitor failure could be a low resistance short.
                                                    If you can’t tell the capacitor type and values what are the shapes and what are the numbers.
                                                    Did you have a fuse and is it possible to connect the esc with the wrong polarity?
                                                    If the capacitors were ceramic types 10nF to 470nF from motor suppression kits they were not to blame.
                                                    What does the esc blurb say about short circuit protection? What do you use for rudder servo and receiver power?
                                                    Do you have a multimeter in your toolkit? They can be obtained for a few pounds and can tell you quite a lot. For example you can tell what current you are drawing.Whether or not your drive train is seizing. but motor revs tell you that. With no ventilation the motors will get hot but,from here,we can’t tell what current you are drawing so what battery capacity do you have and how long does it last.?
                                                    One last thing. When you had trouble before was there any sign of the rudder misbehaving or was it purely the esc cutting out on its own?
                                                    That is not relevant here but it points to whether the esc was previously cutting out or interference was feeding back to the receiver.The choke I prescribed would solve both kinds of issue.
                                                    Are you not near a model boat club with somebody technically minded ? It is easier to pick up things
                                                    How did you kill the last one?
                                                    Edited By 60watt on 20/05/2009 18:15:56
                                                    #21029
                                                    Queequeg Quint
                                                      @queequegquint38270
                                                      Thanks.  The 6 extra capaciators each say 503 on them.  The other three are from MFA, one is larger and say 224Z, the other two say 104.
                                                      Well, I thought maybe there was too much grease in the gears, causing the gears to jam, thus putting a huge load on the motor.  So, I went in and took out most of the grease and guess what?  It worked!  Boat was slightly faster and I got about 45 minutes run time out of it at full throttle.
                                                      When I brought her in, I saw smoke coming out from under the hood.  Opened it up and a cloud of white smoke came out!!  Motor was super super hot!  Worse, the plastic gear box melted right into the gears!!  The motor was so hot that even the solder on the motor was melting away!!!!!!
                                                      When I had trouble before, the rudder was fine.  No odd behavior.
                                                      My battery is 12 volts, with 12 Amp hours.  It is heavy, about 10 pounds.  At full throttle, when the boat is working, I get about 45 minutes with full throttle being true full throttle; then it starts to slow down.
                                                      The motor is in a place which gets little or no ventilation.   Should I change that with a fan or something?  I have a little fan blowing on the ESC all the time.  I use the  BEC on the ESC to power the rudder servo, radio, fan, and lights (which I can switch on and off from the transmitter).  ESC is correct polarity; but I don’t have a fuse in there.
                                                      The last ESC was killed by accident.  I was doing some wiring work when I accidently put some wire where it shouldn’t have been.   A huge spark went up in the air and then my ESC lost it’s ability to go reverse.  I tried all kinds of things to reset it but it didn’t work.
