motor and speed controller trouble
Home › Forums › R/C & Accessories › motor and speed controller trouble
Viewing 6 posts - 26 through 31 (of 31 total)
  • #21030
    60watt
      @60watt
      I didn’t see that last post when I posted.We uploaded at the same time.Give me a chance to read it
      Edited By 60watt on 20/05/2009 20:41:10
      #21031
      60watt
        @60watt
        12 volt and more than 12 amps does not tally with the youtube video where the motor was screaming at high revs.
        I think the gearbox killed the motor by distorting
        The capacitors had nothing to do with it .
        Replace it with a 555 or something with a prop to suit the motor  but don’t use an RE540 on 12 even if it is geared..
        #21783
        Dave Jones 3
          @davejones3
          Contact Dave Milbourn on here he owns ACtion electronics far superior to the rest
          dave
          #22395
          Graham Buddle
            @grahambuddle83370
            Hi all,
            I have a different problem with my Graupner Multispeed 140 fitted with a 6v seed 280 motor. I am driving it with an MTroniks MicroViper 10 Marine speed controller. This howls and ‘sings’  loudly (maybe the motor is humming?), and is too loud for my 24″ canal boat. The speed controller works fine in both forward and reverse other than the noise it generates, presumably due to the swicthing frequency? I would like to add a diesel sound gereator to my model so the noise is a problem.
            I have seen various boats at shows that all seem to glide along almost silently, how is this achieved? I prefer not to use a mechanical speed controller to save wasting battery power.
            What speed controllers would anyone recommend for the MultiSpeed 140 gearbox for quiet running?
            I have e-mailed Graupner and MTroniks. MTroniks have replied and said the speed controller does make a noise when in use.
            Thanks in advance,
            Graham
            #22398
            60watt
              @60watt
               Hi Graham.
              The subject comes up with regularity now: http://www.modelboats.co.uk/forums/postings.asp?th=30276  ( Last week)
              The speed controllers use a different frequency.
              Any compact one that can run at a frequency < 1kHZ
              #22427
                50Hz should do you. More of a quiet, low grumble at dead slow (a bit like me, really………)
                Suit yourself.
