Motor and Prop Survey 2020 Update
Home › Forums › All things floating › Motor and Prop Survey 2020 Update
Viewing 14 posts - 26 through 39 (of 39 total)
  • #29606
      Thanks for these, we seem to be building up a good set of examples.
      Peter Fitness
        @peterfitness34857
        Boat Name: HMAS Bundaberg
        Type: RAN Patrol Boat
        Scratchbuilt
        Length: 1140mm
        Beam: 200mm
        Draught: 60mm
        Weight: 4.55Kg
        Number of propellers: 2
        Motors: 2 x Darke Horse 600
        Propeller type: 5 blade George Sitek
        Propeller diameter: 30mm
        Drive: direct
        Battery type: One 7.2ah 6v SLA
        Running time: about 1 hour at half throttle
        Photo below,
        Peter.
        #29681
        Francis Macnaughton
          @francismacnaughton39461
          Vosper 72′ MTB 224 1/32nd scale
          Type: MTB
          Scratchbuilt from balsa and plastic card
          Length (mm) 695
          Beam (mm) 190
          Draught (mm) 60
          Weight (Kg) 1.3
          Number of propellers One
          Motor(s) used. Mabuchi 550 – sorry but it was bought cheap at a show many years ago without any paper work included! It is not particularly high spec
          Propeller type and description: i.e. 2 blade racing type
          Propeller diameter. 35mm
          Direct drive
          Battery type and capacity. 8.4V 2900 mAH NiMH
          Speed Control MTronik Eco
          Approximate average running time obtained. 10 – 15 mins depending how long is spent on the plane. Originally the model was powered by 8.4V 2AH Nicads and a Maplins kit controller but that was too slow to get on the plane. Changing to NiMH and using a modern low resistance controller gave much better performance.
          Looking forward to the Italeri 1/35th model when it comes out!
          #30217
          Kimosubby Shipyards
            @kimosubbyshipyards
            Colin,
            now the warmer weather is here, I got the beast out of the attic and did measurements for you. She last sailed at Birchwood 2010 and has been tidied up inside since then and the launching protocols have been upgraded to two sawn off glued in broom handles and two large hooks on ropes.
            Data as requested:-
            Boat
            Type: Ro-ro
            vessel
            Kit: Deans
            Marine MV Celastine
            Length
            (mm) 1630
            Beam
            (mm) 255
            Draught
            (mm) 60
            Weight
            (Kg) completed 10
            Weight
            (Kg) with batteries and ballast attached 16.3
            Number
            of propellers 2
            Motor(s)
            used. 2 x MFA Torpedo 500
            Separate
            ESC to each propulsion motor
            Propeller
            type and description: 4 blade; conventional; counter rotating
            Propeller
            diameter 60mm
            No
            reduction ratio or gear drive/belts
            Twin
            rudders are of Becker articulating type
            Bow
            thruster: Raboesch type, 4 paddle, 14mm with ESC control
            Battery
            type and capacity. Three used
            main
            propulsion NP12-6 [6V12Ah]
            bow
            thruster and rear ramp mechanism (and lights) NP4-6 [6V4Ah]
            receiver
            and rudder 6V 5 x AA pack 2400mAh
            Approximate
            average running time obtained. Currently not fully established, but
            has run for 4 hours non stop.
            I use a modified F-14 transmitter incorporating twin side by side throttle sticks, and two other four way sticks as well. The rudder is on a ratchet so engines do most of the close in boat control.
            With the Becker rudder units, she will turn full circle at slow speed in only two boat lengths.
            All areas have been photographed and a full image set is in my album named Sea Crusader. Sorry if its too late.
            Kimosubby
            #30219
              I’m afraid it is too late for the magazine but the data will be very useful on here for reference, so thank you.
                Well, we didn’t quite get the stipulated number of entries but we did get enough to fill the space in the Costruction Special Issue so I decided to award the radio after all and the lucky winner is Robin Lee – congratulations!
                Robin, I have emailed you separately about delivery.
                Robin Lee
                  @robinlee31938
                  Thanks Colin – usually I am very unlucky with prize draws. Hopefully my luck will hold out for today’s Lotto draw!
                  Robin Lee
                  #31436
                  Gareth Jones
                    @garethjones79649
                    I know time has moved on, the article has been published and most of you have lost interest but for the anoraks among you here is another variation on a theme of TIDs. My TID has had is Speed 900BB torque surgically removed and transplanted into Shemarah II. Its replacement motor is a Graupner Speed 720 BB torque, and here is the performance data.
                    Name TID13 (I know there never was a TID 13 in real life)
                    Type Tug
                    Scratch built, ply plank on frame hull
                    Length 900 mm
                    Breadth 230 mm
                    Draught 70 mm
                    Weight 6.4 kg
                    Propellers 1
                    Motor Graupner Speed 720BB torque (type number 6372)
                    Propeller type 4 blade Rivabo brass general purpose
                    Propeller diameter 55 mm
                    Direct drive, no gearing
                    Battery 12 volt 7 amp hour lead acid
                    Duration not known but well over an hour
                    The motor takes 4.7 amps at full power of 54 watts into the speed controller.
                    Battery voltage was 11.65 at this condition.
                    Prop speed was 2140 rpm which is about 52% of the free running speed of the motor.
                    The static thrust from the propeller was 720 gramms max.
                    The attached photos show the motor installation and the tug running at full power on the pond at Goole today. I have not tried towing anything yet but it looks quite good at full power, much more realistic than with the previous motor. Note the picture of the tug on page 1 of this thread is not at full power, its much less.
                    #31437
                    Mark Beard 1
                      @markbeard1
                      Gareth, Much appreciated! Your friendly neighbourhood Anorak! Mark
                      #31840
                      Gareth Jones
                        @garethjones79649
                        Hello Mark and the other anoraks, here is another interesting combination to add to the database and follows on nicely from the TID above because it details the performance of the Speed 900 transplanted into Shemarah 2 and can be compared with the same motor ungeared
                        Name Shemarah 2
                        Type Modern twin rig trawler
                        Scratch built, mainly ply, plank on frame hull and still a long way to go to completion
                        Length 1050 mm
                        Beam 350 mm
                        Draft 140 mm
                        Weight Ballasted to 25 kg (somewhere around the expected complete weight)
                        Propeller One
                        Motor Graupner Speed 900 BB torque (model number6373)
                        Propeller size 75 mm in a Kort nozzle (Prop-Shop matched pair)
                        Reduction gear 2.1:1 using MFA Como Drills belt drive
                        Battery 12 V 7ah lead acid (all the other batteries in the photo are temporary ballast)
                        Measured motor performance at full power static in the water was 10.85 Volts, 6.5 amps, 71 watts.
                        Propeller speed was 2080 rpm which is equivalent to a motor speed of 4368 or 67% of the motor free running speed which is a pretty good match.
                        The static thrust was measured at between 1800 and 2000 grams.
                        The photo below shows that perfomance on the water looks good with plenty of power in reserve and the ability to make some really big waves if you are in that sort of mood.
                        Edited By Gareth Jones on 19/09/2011 09:42:03
                        #83075
                          brush motor specs.jpgprop specs001.jpgprop specs002.jpgprop specs003.jpgprop specs004.jpgprop specs005.jpgprop specs006.jpgHi All
                          This is a very grey area for us model boaters, but in the planes with brushless motor you get all the data !!!
                          Prop size, pitch, thrust, Amps, voltage and required ESC.
                          I found a good start is with the Raboesch Prop Chart which gives you all the specs including vessel type and mainly the maximum RPM for each prop.
                          Brushless motors are easy to work out, divide maximum prop speed by the voltage (7.2volts(2S Lipo)11.1volts(3S Lipo)).
                          EG 11,000 rpm divide by 7.2 equals 1500kv and 11.1 is 1000kv.
                          A bit of rounding out to get to a motor kv which is available.
                          Motor size, the first two numbers are the diameter and the second two are the can length.
                          EG 3639-750KV is 36mm diameter(about the same as a 540 brush motor) and the second two 39mm is the can length, note the larger the length the more powerful the motor.
                          Onto 540 rock crawler brush motors which I was talk into buying for my Hellen Fishing Boat (all 14 pounds of it).
                          I found at least some info on these at 7.2 volts from websites.
                          Maximum rpm for a 20 Turn(18400), 27Turn(15,000), 35turn(12,500), 45Turn(9,500), 55Turn(7,700), 65Turn(7000), 80Turn(4450).
                          So using my brushless motor maths a 80Turn equals a 600kv brushless!!!
                          HOPE I HAVE NOT LOST EWE ALL !!!!
                          As for the other brush motor specs the best chart I found I added below.
                          Some of the other motor spec charts are a dog's breakfast and totally poor.
                          So checkout the pics below and post ideas !!!
                          #91440
                            I'm sure many of you will recall this particular topic where the data gathered was used in an article about selecting motors and props for the Model Boats Special Isse published in 2011.
                            In the years since then the subject of matching the motor and prop to particular models has come up again and again and Editor Lindsey Amrani and I feel that it would be useful to update the article and feature it in the regular magazine which of course has a wider readership than did the Special Issue.
                            Looking at the original, most of the information is still quite valid but it was biased very much towards brushed motors and NiMH/SLA batteries whereas brushless motors are now much more common and are often the first choice, even for scale models. Likewise, the greater availability of LiPos and smart chargers has made this power source far more popular due to it's light weight/high power ratio.
                            I am therefore looking for examples of brushless motors being used in models using the same data that we used before together with photos of either the model or the interior layout. These are repeated below. If you scroll back through this topic, the previous examples can be seen.
                            I look forward to your contributions (including Ashley's innovative models).
                            The list of parameters that I have identified is as follows. We need all of them to do an effective job.
                            Boat Name
                            Type: ie. tug, destroyer, cabin cruiser etc.
                            If a Kit – which kit?
                            Length (mm)
                            Beam (mm)
                            Draught (mm)
                            Weight (Kg)
                            Motor(s) used. (specific rather than generic i.e. Not just ‘540’ but ‘Dean’s Kondor’ for example so we know exactly which motor is being referred to.)
                            Propeller type and description: i.e. 2 blade/3 blade/4blade etc. conventional or racing
                            (precise prop details if available i.e. manufacturer and product ref
                            Propeller diameter.
                            If geared drive what is the reduction ratio and are gears or belts used?
                            Any special comments on the setup. (new item)
                            Please don’t use this topic to ask questions about which motors to use, it is intended for gathering information only! I have started a new topic for any discussions of a general nature that yield useful information for the article.
                            Edited By Colin Bishop on 18/09/2020 11:21:39
                            #91454
                              As stated above, please only post data on this topic and use the following topic for discussions.
                              Many thanks,
                              Robin Lee
                                @robinlee31938
                                Hi Colin. Since my last contribution to this thread I have made several brushed motor models but I have two brushed motor models, one complete, one on the stocks (Model Slipways Vliestroom).
                                My contribution to the data base update –
                                Boat Name: USN PT212
                                Type: US PT Boat type Higgins 78 foot fast planing hull
                                If a Kit: Dumas PT212 Higgins 78 foot 30:1
                                Length: 762 mm
                                Beam: 203 mm
                                Draught: –
                                Weight: 2.3 Kg
                                Number of propellers: 2 (NB kit designed for 1, actual PT boat had 3)
                                Motor(s) used: 2 off Turnigy D2830-11, 1000kv 210 watts, 21 Amp max, 7.4-14.8 volts
                                Propeller type and description: 2 off Raboesch type RAB174-03/04, 4 blade, 35 mm dia, 35.9 mm pitch
                                Propeller diameter. : 35 mm
                                If geared drive what is the reduction ratio and are gears or belts used: n/a
                                Battery type and capacity: one off 9.6 volt NiMH 4300 mAh
                                Approximate average running time obtained: 30 minutes (not flat out say 50% cruising, 50% having fun!)
                                Comments: Uses two off HobbyKing Marine ESCs maximum 30 Amp. ESCs are not water cooled but temperature of the ESCs and motors is reasonable if boat is used sensibly. The kit in its 2 motor set up is a little heavy so a Lipo battery might have been a better choice but the boat with its NiMH battery floats only about 3 mm too deep and performs well. The drive train installed is a little too powerful for scale speed but I use a programmable transmitter permitting throttle stick maximum demand to be adjusted. I have found a setting of 70% limit gives a good approximation to a scale maximum speed for this 40 knot boat. 100% demand which would be the default for a non-programmable transmitter is a bit hairy for the model particularly on tight turns where a capsize looks possible!
                                Edited By Robin Lee on 19/09/2020 14:14:51
                                Edited By Robin Lee on 19/09/2020 14:15:24
