Name of vessel: The Ambassador
Hull type: Lobster boat
Hull: fiberglass, plus wood freeboard to allow the boat to carry more weight
Length: 35 inches
Width: 12 inches
Draft: 5 inches
Motor: MFA Como Torpedo 850, geared down with belt drive: 2.1:1
Prop: 65mm 4 blade brass
Weight, with 12volt 12AH battery: over 12 lbs (American pounds)
Run time: about one hour with aggressive driving
In this video, the camera is on board one lobster boat, trying to chase the Ambassador. You can see how fast the Ambassador’s motor/prop setup is.
In this next video, the camera is inside the Ambassador. You can hear how this motor sounds Note: in the beginning, you hear the humming of two cooling fans (one for the motor, one for the Viper ESC). Not sure if I really need them, but when I first got into this hobby seriously 2 years ago, I smoked a motor in the Orca. Been fearful of doing that again ever since:
In these pictures you can see the veritable miracle that is the way I mounted this motor. I can’t believe it works but it does perfectly.
The motor is bolted to 4 wood blocks which are cold welded to the hull (at an angle!!!!) It actually works I and use this boat alot!
The only thing I had to do was add some cold weld to the universal joints beause they started to separate. Also, my prop came loose once, but I caught that before I lost the prop and added some extra lock tight!
If anyone can tell me, I was wondering if I can squeeze out some more thrust by switching to a 5-blade prop…. Same diamaeter becuase I can’t fit a bigger one down there.
