Kingfisher Fishfull Thinking 56 day Build
Home › Forums › Scratch build › Kingfisher Fishfull Thinking 56 day Build
Viewing 25 posts - 26 through 50 (of 101 total)
  • #42808
    Nigel Edwards
      @nigeledwards16506
      Day 26 Continued Killing time so made tempory stand
      #42809
      Nigel Edwards
        @nigeledwards16506
        Finaly Day 27 Let the deck planking begin
        Used a metal filler spreader to give me 1mm spacing in between planks all planks had the sharp edge rounded off with sand paper..
        Will continue tomorrow over half done
        Edited By nigel edwards 1 on 09/08/2013 23:56:39
        #42810
        Nigel Edwards
          @nigeledwards16506
          Day 28 Decking been finished, well nearly all planks laid and the starboard side shaped ready for side rail.
          #42811
          Nigel Edwards
            @nigeledwards16506
            Day 29 Been a good day weather was boiling but managed to finish shaping the port side of the deck planks and also fitted the side rails and posts to both sides.
            #42812
            Nigel Edwards
              @nigeledwards16506
              Day 30 Today I filled and sanded the side rails and fitted the Bumper Rails all round.
              #42813
              Nigel Edwards
                @nigeledwards16506
                To be continued
                #42819
                Nigel Edwards
                  @nigeledwards16506
                  Day 32 sealed the hull with two coats of fiber glass resin first with tissue paper, sand down and second gel goat..
                  #42820
                  Nigel Edwards
                    @nigeledwards16506
                    Day 33 Today I made the top rails used the same timber as i did for the bump rail 10mm half round. I used the template from the deck to place one row of screws for each side on my work area to the exact shape of the rail then as i steamed the wood soft placed more screws the other side to hold in place and in to shape and allowed to dry.. I have glued them in place on the side rails already will show the results tomorrow once dry..
                    #42821
                    Nigel Edwards
                      @nigeledwards16506
                      Day 33 continued ok I told a fib weather cooled slightly so went out to the workshop to check to see if hand rail had dried and it had so I couldn't wait out came the filler and sand paper.. here's how it ended up..
                      #42822
                      Nigel Edwards
                        @nigeledwards16506
                        Day 34 Today the hull had a good sand masked and prime coat
                        #42823
                        Nigel Edwards
                          @nigeledwards16506
                          Day 35 The task was to make a start on the cabin, all side parts cut to shape and windows rough cut out, also done a dry fit to see what it looks like masking tape to hold temporary.. the front section is taller than needs to be as I wanted to check hight once on the deck, looking at it needs to be shorter..
                          #42824
                          Nigel Edwards
                            @nigeledwards16506
                            Day 36 dry fitted the mast and glued cabin frames
                            #42825
                            Nigel Edwards
                              @nigeledwards16506
                              Day 37 Drilled vent holes in the floor of the cabin to allow air in and out from the hull to help with cooling, the front side windows and the rear window will be quarter open to allow air flow, also made the roof for the cabin and hatch for the nets and part finished the planking around the cabin and hatch, plus I did slim down the mast at the top..
                              #42826
                              Nigel Edwards
                                @nigeledwards16506
                                Day 39 Today I under coated the cabin and hatch.. and spent a fair few hrs window framing and adding trim to the cabin, the fish net is a hair net from the chemist put this in the pictures because the hatch looked like a swimming poolcheeky
                                #42827
                                Nigel Edwards
                                  @nigeledwards16506
                                  Day 40 After a bad start to the day spent 2 hrs messing with all the running gear to make sure all is working before paint lots of head scratching only to find out that the new transmiter and receiver DX5 I brought was faulty grrrr so back to the shop with that for a replacement..
                                  But I did manage to get some masking done and paint on the cabin
                                  #42828
                                  Nigel Edwards
                                    @nigeledwards16506
                                    Day 41 Bath test today and it floats with no leaks cool put all the running gear in and worked out the ballast required and marked the hulls waterline she sits well in the water..
                                    Wow some weight was added to get the hull to sit right for waterline..
                                    Here is the calculations.. Boat with running gear and cabin in place 2.425 kilo.
                                    ballast required front 0.990 kilo. ballast rear 0.910 kilo. battery mid section 1.340 kilo. Total weight 5.665 kilo…that's some weight
                                    #42830
                                    Nigel Edwards
                                      @nigeledwards16506
                                      Day 41 continued Using the pencil marks placed in bath test I sat the boat on a level work top on my stand made sure she was sat correct and level I made a tool to mark the hulls water line from a scrap of wood and pencil and masking tape and keeping the wood tool flat on the worktop marked a line all round the hull, then using tamiya's masking tape I have my waterline masked ready for hull painting..
                                      Also found some time to continue painting the cabin and made some hatch covers.. you can see the colour scheme I'm going for..
                                      Edited By Nigel Edwards on 10/08/2013 10:02:11
                                      #42831
                                      Nigel Edwards
                                        @nigeledwards16506
                                        Day 42 weather perfect for spraying the hull
                                        Plus I clear coated all the woodwork on the cabin and deck and added the bars to the rear..
                                        #42832
                                        Nigel Edwards
                                          @nigeledwards16506
                                          Day 43 Today just done a couple of small jobs fitted the windows and as I said early on in the build I had the two quarter windows and the rear door window quarter and half open for airflow to the hull..
                                          #42833
                                          Nigel Edwards
                                            @nigeledwards16506
                                            Day 45 Today rummaged through the fittings box, over the next couple of days as the weather is too damp for painting I shall be making a few fittings..
                                            It all started with making the cabin mast and cabin roof vent, the brass fitting at the bottom of the mast is a 8mm olive used for plumbing..
                                            #42834
                                            Nigel Edwards
                                              @nigeledwards16506
                                              Day 45 continued Now for some brass work first time I have worked with the stuff time to make the exhaust..
                                              The parts cut ready
                                              Inner tube soldered and cleaned
                                              Then the outer soldered and cleaned
                                              And the day ended with the result rather proud of my self for this bit of work
                                              #42835
                                              Nigel Edwards
                                                @nigeledwards16506
                                                Day 46 Ok I had to solve the problem of the hull access deck lifting in the middle here what I came up with..
                                                22mm plumbing fitting and a brass latch 2 nuts a bolt and a block of wood
                                                Bolted through deck twist and turn to latch over hull access deck..forgot to mention fan as been added above the motor as well
                                                Hey presto two barrels done the job nicely.
                                                #42836
                                                Nigel Edwards
                                                  @nigeledwards16506
                                                  Day 46 continued Little bit a of brass work eyelets cut from small latches for cabin mast rigging and handles for hatch covers.
                                                  #42837
                                                  Nigel Edwards
                                                    @nigeledwards16506
                                                    Day 47 The hull got painted satin black 4 coats
                                                    #42838
                                                    Nigel Edwards
                                                      @nigeledwards16506
                                                      Day 47 Continued Winch building, spent some days thinking about it and this is what I came up with all parts from the fittings box..
                                                      And all painted. the belts will be fitted when paints dry…
