Kingfisher Fishfull Thinking 56 day Build
Home › Forums › Scratch build › Kingfisher Fishfull Thinking 56 day Build
Viewing 25 posts - 1 through 25 (of 101 total)
  • #42784
    Nigel Edwards
      @nigeledwards16506
      This is what i have hand crafted from plans 1958 kingfisher, I will add the full build hope you all enjoy
      Edited By nigel edwards 1 on 09/08/2013 22:33:06
      Edited By nigel edwards 1 on 09/08/2013 22:36:14
      #6891
      Nigel Edwards
        @nigeledwards16506
        New to the world of boat building this is my first build
        #42785
        Nigel Edwards
          @nigeledwards16506
          It all started with a couple of days clearing the shed of junk building the work bench and shelving with the help of one of the younger boys, had to refelt the roof which I could of done with out as it broke into the build budget but we have to be water tight..
          #42786
          Nigel Edwards
            @nigeledwards16506
            Day 3 started with a raid of my mothers loft, found some 9mm ply from my late fathers projects which I shall use for the keel and frame assembly, also found some mdf slats from a kitchen blind 25mm wide 2mm thick bends and twist nicely so shall give this a go for planking the hull..
            #42787
            Nigel Edwards
              @nigeledwards16506
              Printed out the plans 16 pages of A4 paper per plan done this 3 times 1 set for master others sets for templates, wife was not very happy as I run the ink out in the printer oopps..
              Edited By nigel edwards 1 on 09/08/2013 23:04:36
              #42788
              Nigel Edwards
                @nigeledwards16506
                After spending a couple of hours tangled up in paper cuttings and sticky tape I managed to fit all frame templates on one sheet of recycled ply stuck down with the kids glue stick robed from the stationary draw, "I will replace it honest"
                Edited By nigel edwards 1 on 09/08/2013 22:53:14
                Edited By nigel edwards 1 on 09/08/2013 22:53:40
                Edited By nigel edwards 1 on 09/08/2013 23:05:46
                #42789
                Nigel Edwards
                  @nigeledwards16506
                  Day4 After waiting for my new jigsaw to arrive as the old one was rubbish, I rough cut out all the pieces will cut out the notches for the keel and deck beams after sanding and shaping.
                  Edited By nigel edwards 1 on 09/08/2013 22:54:07
                  Edited By nigel edwards 1 on 09/08/2013 23:02:44
                  #42790
                  Nigel Edwards
                    @nigeledwards16506
                    Day 8 after a couple of days break I took some advice and made a new jig today made my own stone circle "block henge" hope this works
                    Edited By nigel edwards 1 on 09/08/2013 23:03:35
                    #42791
                    Nigel Edwards
                      @nigeledwards16506
                      dry fit of frames on jig, don't breathe as it will go down like a domino's and yes that did happen about 5 times
                      Edited By nigel edwards 1 on 09/08/2013 23:06:56
                      #42792
                      Nigel Edwards
                        @nigeledwards16506
                        Day 9 Had a lazy day today, all that,s been done is I shaved and sanded the angles on the frame pieces so planking fits flush. need to wait for some parts to turn up prop shaft mainly so i can line up and drill the keel before glueing frame sections
                        #42793
                        Nigel Edwards
                          @nigeledwards16506
                          Day 12 Well my parts never arrived today so not to waste a day I made the mast, hand plain and sand paper done the trick..
                          Edited By nigel edwards 1 on 09/08/2013 23:12:12
                          #42794
                          Nigel Edwards
                            @nigeledwards16506
                            Day 13 Let The build continue
                            #42795
                            Nigel Edwards
                              @nigeledwards16506
                              Well bit of progress today after parts arrived and test fitted shaft motor alignment all worked out nice dropped into place between frames nicely.. frames are all glued to keel now, also shaped and fitted the transom..
                              #42796
                              Nigel Edwards
                                @nigeledwards16506
                                Day 14 The planking has started drawing pins to hold while glueing..
                                #42797
                                Nigel Edwards
                                  @nigeledwards16506
                                  Day 15 Slow progress today with the Pin Soldiers, what a task this is..
                                  #42798
                                  Nigel Edwards
                                    @nigeledwards16506
                                    Day 16 Well the hull planking is done, that was the worst job by far, and when I removed it from the jig the rear frame was out of line grrrr apart from that it seems to be all in shape.. will give it a full day to dry off now before removing all them pins..
                                    Edited By nigel edwards 1 on 09/08/2013 23:29:07
                                    #42799
                                    Nigel Edwards
                                      @nigeledwards16506
                                      Day 17 Ok all them pesky pins was removed today it held up great, have pre sanded it ready for filler, shape don't look too bad I am pleased with the result so far
                                      #42800
                                      Nigel Edwards
                                        @nigeledwards16506
                                        Day 18/19 update so far the last couple of days I fitted the base for the motor mount lined up great, also dry fitted the rudder had to make a block for the rudder to sit flush and straight for a good seal, as you can see in the pictures quite pleased with the result bit of carving with a wood rasp..
                                        #42801
                                        Nigel Edwards
                                          @nigeledwards16506
                                          Day 19 continued under deck cut out trimmed shaped and dry fitted using 3.6mm ply been a busy afternoon..
                                          #42802
                                          Nigel Edwards
                                            @nigeledwards16506
                                            Day 20/21 update filled and sanded the hull..
                                            #42803
                                            Nigel Edwards
                                              @nigeledwards16506
                                              Day 22 Been too hot to work for my liking in the 30's easy, rare weather for us brits, so took it easy and just made the servo mount. and made the most of the weather..
                                              #42804
                                              Nigel Edwards
                                                @nigeledwards16506
                                                Day 24 Waiting for the deck planking to arrive have ordered Walnut Strips 1.5mm x 10mm in the mean time I made the side rails once deck is planked shall fit these..
                                                #42805
                                                Nigel Edwards
                                                  @nigeledwards16506
                                                  Day 25 parts arrival.. Mfa Titan High power 12v 3Ah Lead Acid Bat, 12v 7h charge plug charger, Viper Marine 15 speed control all from**LINK**
                                                  10ml Waterproof Marine Grease from Nautical Marine Models (ebay)
                                                  #42806
                                                  Nigel Edwards
                                                    @nigeledwards16506
                                                    Day 25 continued Made a battery mount for the titan piece of ply 2 screws and screw cups and a piece of rubber glazing seal from a green house to secure it, bat fits perfect in between frames with about 1mm clearance was lucky there.. will glue in to place at a later date as it can go in 1 or two places within the hull depending on ballast and how she sits in the water..
                                                    #42807
                                                    Nigel Edwards
                                                      @nigeledwards16506
                                                      Day 26 Today so far have cut the side rails supports bit longer than they need to be from 6 x 6mm square pine will be glued in place when under deck planked.. finding any job to do now wile waiting for this walnut to turn up grrrrrr
