How do members rate RC equipment
Home Forums R/C & Accessories How do members rate RC equipment
Viewing 25 posts - 1 through 25 (of 28 total)
  • #62535
      Hello All
      This has probably been covered before but I would like to raise the question of reliability and workability of different RC equipment.
      Has anybody any experience of FlySky kit?
        Dodgy Geezer 1
          @dodgygeezer1
          I have got a number of RadioLink sets. These are VERY cheap Chinese sets.
          I find that the trim and finish is poor – but the insides look fairly similar to all other radios. The components will be cheaper versions, but they have always worked for me. The quality control can be poor – it's worth checking the soldering for poor connections if you buy one.
          FlySky (not to be confused with FrSky, which is a different company) is a bit more expensive, and very popular with the penny-pinchers. Like a lot of these Chinese sets, I think several early sets suffered from poor software. Google 'FlySky problems' to get a feel for these…
          #62539
          Kev.W
            @kev-w
            I have a Flysky FR T6 & find it more to my liking than my other set, which is a Spektrum Dx5E.
            #62542
              I have a Hobbyking Turnigy IA-6 2.4G 6 channel, the telemetry is a bonus with temperature, revs and voltage sensors.
              On board adjustments for servo end stop, changing servo direction, etc.
              Supports up to 20 models with naming for each.
              I use these for a few years and had no problems!!!
              They only come with one receiver and no servo's, but, Hobbyking servos work very well.
              #62554
              Dodgy Geezer 1
                @dodgygeezer1
                Turnigy seem to be rebadged FlySkys…
                #62557
                  All good info
                  DG
                  Is Turnigy rebadged FlySky?
                  #62564
                    Has anybody come across this.
                    RadioLink AT9
                    Size: 183 x 193 x 100mm
                    Frequency: 2.4GHz ISM band (2400MHz to 2485MHz)
                    Modulation mode: QPSK
                    Channel bandwidth: 5.0MHz
                    Spread spectrum: DSSS
                    Adjacent channel rejection: >38dbm
                    Transmitter power: <100mW(PCB testing), <20dbm(3 meter air testing)
                    Operating Current: <105mA
                    Operating Voltage: 7.4~15V
                    Control distance: more than 900 meters ground, 1.5kms air
                    Channel: 9 channels, 5~9 channels are customizable
                    Simulator model: under the simulator model the transmitter action turn off, change to power saving model
                    Screen: 2.8 inches 16 colourful screen, 240 x 320 pixels
                    Switches included: three 3-section, four 2-section, one reset switch and four proportional potentio-meter
                    Compatible model: Include all 120 degree and 90 degree swashplate helicopter, all fix wing and glider, five flying model and aircraft
                    #62565
                      Clear as mud. I bet the Instruction Manual is a hoot!* You'll particularly appreciate the "humanised switch positioning", Paul, while I was very much heartened to see that "vibration alarming is used to avoid any ignorance in a noisy condition".
                      (*In truth I've downloaded the English Manual and I have to say that I've seen much worse examples of Chinglish, but there are pages and pages of tables showing the programming screens and options – very few of which you'd need for a boat. It was like watching the weather forecast on the BBC – you know you've seen it but you can't recall a thing about it five seconds afterwards!)
                      Mind you, with a receiver it just about breaks my stated £80 barrier and it's a smart-looking piece of kit – but I still don't think I could bring myself to pressing the Send key on the Confirm Order screen. I'd need to have a very close look at one first.
                      As for the Dx5e, the words bargepole, touch, with and wouldn't come readily to mind. I really didn't like mine at all and eventually sold it to Kim Holland!
                      Suit yourself, Paul.
                        Hi Dave
                        I have a pal over in Hong Kong and have an option on importing some RC gear including these transmitters and I wanted to know if anybody had ever used them.
                        Why don't you like the Dx5e?
                          It's a long time since I had it and frankly I'd forgotten about it, but I didn't like the accuracy of the sticks and the fact that the pulse width on the channels wasn't centred at 1.5mS. Indeed, on the throttle it was of the order of 1.38mS and required surgery on the stick unit to get it back to something like. I also wasn't impressed with the way it was assembled and I remember that the receiver aerial emerged from the sharp plastic case with no grommet and was chafing so badly that it had just about worn through. The Tx was also quite long and bulky. Wombat had a Dx6i at about the same time and the difference in the quality of the two sets was extraordinary.
                          Would your pal be prepared to send a sample AT9 set 'for inspection and appraisal' (CRUNCH! BANG! THUD! CRASH! Hints dropping like hailstones)?
                          The only caveat I would give is to do the maths. Chinese manufacturers are often prepared to sell single units direct to end-users for the same price (or for very little more) that they charge trade customers for bulk purchases. Interpose two agents in the chain and you could end up with unsaleable product.
                          BTW If any ardent Dx5e fans out there feel inclined to write and champion their set then please feel free, but don't think it will change my opinion one iota.
                          Edited By Dave Milbourn on 07/01/2016 15:33:32
                          #62572
                            I thought that it was hail stoning outside but when I looked out of the window it turned out to be some very heavy hints smashing through the greenhouse.
                            #62575
                              As Dave says, there is very little wriggle room for UK agents when importing this sort of gear which is why a fairly large one which will remain nameless has recently stopped doing so. Unless you are Howes Models it is unlikely that you would be able to make it work and it is you that will have to sort out all the after sales issues which could easily negate any money you might make.
                              Also, as you will have noticed, people in the market for economy Chinese gear tend to go for the lowest price which usually means direct from China.
                                O, yes! I'd forgotten the after-sales issues! It's bad enough when you make the stuff yourself and just have a customer to explain his perceived "problem" to – that's often if you can make head or tail of it. Been there; seen it etc etc. If you need to pass that query on to the manufacturer – especially one who speaks very little or no English – then you really are stuck between a rock and a hard place.
                                My advice? Avoid like the plague. You don't need the hassle.
                                DM (Off for a Chinese now!)
                                #62579
                                Dodgy Geezer 1
                                  @dodgygeezer1
                                  Posted by Paul T on 07/01/2016 13:57:59:
                                  RadioLink AT9
                                  If you want to practice your Chinglish, Michael Huang, who is 'the staff' of Radiolink, would be happy to talk to you here…  especially if you " have any questiton or want to buy AT9, AT10, "
                                  Dave might like to try a hint….
                                  Good Luck!
                                  Edited By Dodgy Geezer on 07/01/2016 18:35:29
                                  Edited By Dodgy Geezer on 07/01/2016 18:36:34
                                  Edited By Dodgy Geezer on 07/01/2016 18:37:23
                                  #62580
                                    Thanks for the link, D-G, but I already have a decent radio (with seven receivers) and so I'm not looking for another one, despite all my talk of dropping hints. I shall leave Dr T to make his own mind up, once he's unscrambled it from debating global warming with you.
                                    (BTW We decided to go to the local Wetherspoons and have a curry instead – it was excellent).
                                    Dodgy Geezer 1
                                      @dodgygeezer1
                                      And I'm on the lookout for a 40Mhz 7-channel job – you've no idea how hard they are to find…
                                      #62586
                                      Banjoman
                                        @banjoman
                                        DG,
                                        According to their website, the Danish model boat specialist shop Modelskibet still have four Robbe FC-16 Boat´n´Truck, 40 MHz in stock ("sold while stocks last" they say) ; see **LINK**.
                                        The site is in Danish only, I'm afraid, but you could try running it through Google translate if you were interested. The price of 2499 Danish kroner would be about £235, while I don't know what the freight would come to.
                                        /Mattias
                                        Edited By Banjoman on 08/01/2016 08:22:37
                                        Edited By Banjoman on 08/01/2016 08:23:20
                                        #62589
                                        Kev.W
                                          @kev-w
                                          Posted by Dodgy Geezer on 07/01/2016 21:09:06:
                                          I'll have a look in the boathouse on sunday, we've got a box of old handsets in there that belonged to a deceased member of the club & I'm sure there were some 40meg sets among them.
                                          #62591
                                          Dodgy Geezer 1
                                            @dodgygeezer1
                                            I'll have a look in the boathouse on sunday…
                                            Most kind. I'm surprised that the submariners (which is what I want one for) haven't pounced already! The Danish item looks superb, but a bit expensive, particularly for experimental purposes…
                                            Unlike Dave, I'm always looking for items that cost less than the cheapest possible. I have a Radiolink T7f 7-channel 2.4Ghz combo which I bought new off ebay for £20 (+£5 postage!). I don't suppose Dave has any receivers which were that cheap….
                                            #62592
                                            Kev.W
                                              @kev-w
                                              Posted by Dodgy Geezer on 08/01/2016 16:16:04:I'm always looking for items that cost less than the cheapest possible.
                                              Ayup old cock, I's a Yorkshireman, it can never be toooooo cheap (we're careful wi us cash up north) wink
                                              One of the reasons I like my FlySky is, it came with a receiver & postage, brand new in the box, for no more than £34.95 yorky punds. I also bought 3 extra receivers from 'Gearbest' for the low low price of £15 + free postage. (no smilie available with a big enough grin)
                                              Edited By Kip Woods on 08/01/2016 16:46:21
                                              #62595
                                                No, I don't, but price isn't a challenge to me. "Careful" doesn't have to equate to "cheapest" – and there's Yorkshire blood flowing through this hulk.
                                                Kev.W
                                                  @kev-w
                                                  DG,
                                                  Sorry mate, had a rummage through the transmitters, only 2 or 4 channel in 40meg I'm afraid, can't help this time.
                                                  #62605
                                                  Dodgy Geezer 1
                                                    @dodgygeezer1
                                                    Posted by Kip Woods on 10/01/2016 13:03:01:
                                                    DG,
                                                    Not surprising – thanks a lot for looking. Though if someone has a cheap 4-channel I could probably make use of that. It's hard enough to find them! PM me if that's the case…
                                                    #62606
                                                    BRYAN ASTON
                                                      @bryanaston57723
                                                      Greetings
                                                      Regarding reliable r/c equipment I have four flysky transmitters , cheaper than buying separate receivers, never had any trouble from any of them, average price 20 pounds or less. If they to go wrong chuck them in the bin.
                                                      Bryan Aston
