Hi chaps I’ve just been reading your threads on the subject of EKranoplan and trying to emulate it in a model. The whole idea is fascinating, and whilst reading your words I suddenly thought that a tunnel hull racing boat does just that with the lift obtained from the air beneath taking some of the boat’s weight off the catamaran hullsso the thing cuts down on drag by reducing the amount of contact with the water, you could take a model tunnel hull that already works, and add a pair of stub wings outboard to provide a bit more lift. putting that bit down has made me think about it and ponder the possible problems, and immediately I spy a snaggette in the balancing of lift on each side If your port stub gives you more lift than your starboard one, the boat will do a pretty little pirouette and do a passable imitation of a submarine, so each of the stubs must be an exact mirror image of the other.
There are some brilliant projects being mooted at the moment, and I would dearly love to be involved in one. I think it was MMI that published a bit about trying to exceed 200Miles per hour with a fast electric model boat. What about that ? How would you measure that, ? it could only be done electronically
