Hi Ray,
I decided to repair it in the end – took a bit of time to do but hopefully will improve the end product. Mixture of multi-tool cutting disc like you said, and a bit of chopping out did the trick! Not the easiest place to do repairs …
I've started with the filler as well – very unusual stuff – almost unbelievably light – thanks for the tip.
I did a dry fit test with the tube as well, so once the repair and filler is dry I'll put that in next. Nothing seems to dry in this cold
After that will try the balsa block shaping part as well. Then can finally work on the sides.
Cheers,
Simon
