what type esc and battery
Home › Forums › R/C & Accessories › what type esc and battery
  • #67385
    Peter Etherington 2
      @peteretherington2
      I am very new to model boating (electrical) and I have bought 2 x 545 type motors (5 pole) and was wondering what type of esc I should be looking at, and what type of battery, It is a minefied out there. Many thanks, Peter
      #5438
      Peter Etherington 2
        @peteretherington2
        #67386
          Peter,
          A lot will depend on what the specifications of the motors are and what you intend to do with them. If you haven't already done so, have a look at Dave Milbourn's article here **LINK** for some basic background.
          Then give us a bit more information on what you are doing.
          Edited By Colin Bishop, Website Editor on 27/08/2016 17:59:01
          #67387
            Here's a further guide through that minefield which will take you to a thing called P94….. **LINK**
            As Colin says, we will need to know more about the boat if you require specific advice on batteries etc.
            Peter Etherington 2
              @peteretherington2
              Agggrrrr……… This is the spec of the two 545 motors I have got, these are the only electrical items I have bought as yet, I have a 46 inch plastic hull which I bought from Models by design (sangestia) two prop shafts, props, and rudders, and a set of 2.4 radio gear. high revving 5 Pole motor for universal applications.
              Operating Voltage 6-12V
              Size: 67mm long 35mm diameter.
              Speed 17,400 RPM @ 7.2V.
              Free load drain 1.95A @ 7.2Volts
              Shaft size: 3.2mm
              Thats about the size of it folks. Peter
              #67394
                Peter
                As you've probably gathered, those motors are not really suitable for that model – they are much too fast and hungry for current. This is a pretty large hull and would certainly stand 700-size motors, but running at around 8000 rpm and turning something like 45mm 3- or 4- blade props. I would suggest a pair of these **LINK** running on 9.6v. That's a standard 8-cell NiMH pack. If you connect them up according to this diagram **LINK** but using the 775 motors and two parallel-wired 9.6v NiMH packs with a P103 (instead of the 12v SLA batteries shown) then I reckon you will have a sound basis for a performance boat. If you buy the P94 then set it to Mode 4 (50% mix). One thing you must avoid is excess weight, so don't even think of using a big SLA battery for power.
                O – by the way, avoid the Futaba 6J or 7C radios as they are incompatible with the P94. I personally use and can recommend Hitec.
                Good luck!
                Peter Etherington 2
                  @peteretherington2
                  Many thanks Dave.
                  #67408
                  Peter Etherington 2
                    @peteretherington2
                    Just ordered 2 x 775 dc motors
                    #67411
                    Peter Etherington 2
                      @peteretherington2
                      So lets get this right, you are saying that I need two battery packs @ 9.6v then to a P103 then to a P92 then to a P94 duel esc mixer then to the two motors, Peter
                      #68627
                      Peter Etherington 2
                        @peteretherington2
                        Well ive bitten the bullet and bought a P103,P107, P94 & P95. Just need to build the boat and get two 9.5 battery packs. Peter
                        #68647
                        Peter Etherington 2
                          @peteretherington2
                          What 9.6v mah battery packs would anyone recommend please, Peter
                          #70924
                          Peter Etherington 2
                            @peteretherington2
                            #70927
                              Either will do the job – it depends on the actual space available (for the shape of the pack) and the duration required (battery capacity). There's more information on the supplier's main website **LINK**
                              Peter Etherington 2
                                @peteretherington2
                                thanks Dave, your a star
                                #70935
                                  angel?
