what tx / rx combo ??
Home › Forums › R/C & Accessories › what tx / rx combo ??
  • #61354
    rob smith 4
      @robsmith4
      I've been out of RC for a long time and my how things have changed.
      I'm after a basic setup 4 channel and my needs wont increase so can anyone recommend a basic setup that wont break the bank ?
      can you use 2.4G for surface craft ?
      sorry for what may be daft questions but the 2.4G is a new one on me.
      Cheers
      #5391
      rob smith 4
        @robsmith4
        how things have changed !
        #61355
        rob smith 4
          @robsmith4
          Found another thread about this so now a little more informed. Thanks
          #61357
          Dodgy Geezer 1
            @dodgygeezer1
            It might be interesting to note the changes which people have noticed since the 80/90s in the boat modelling field. (Possible topic for Model Boat article?). Here's a starter for 10…
            – Fewer Model shops around – so much more postal purchasing
            – The rise of China and internet shopping
            – I/C motors fall out of favour – brushless electric motors arrive
            – Battery technology continues to improve, with the arrival of Lipos
            – Glue and materials technology changes – carbon fibre and foam board, but good quality traditional balsa/ply becomes harder to source…
            – Seems to be less scratch building – ready-made kit is more common, particularly fast boats!
            – 2.4Ghz technology is booming – VERY cheap and full of functions, BUT these are mainly aimed at helicopters/drones and of little use to boaters. Submariners get hit as 2.4Ghz doesn't work for them…
            – On-model cameras, autonomous control and visual feedback to the operator are now readily available, though not cheaply (yet!).
            – Few youngsters joining the hobby – and fewer venues available for it… frown
            That ought to bring some commentators out of the woodwork…!
            #61365
              Posted by rob smith 2 on 13/11/2015 07:14:41:
              Cheers
              I got a Saturn set as my entry into 2.4GHz. 4 proportional channels and one on a switch, and it was priced so as not to break the bank. The extra receivers are not the cheapest, BUT when you look at the cost of a cheap 27MHz RX then add the cost of a pair of crystals, it looks a lot better.
              Yes, they work on surface craft. You do need to be careful where you mount the aerial on the RX as it will be very short and they are very line of sight.
              #61371
              Dodgy Geezer 1
                @dodgygeezer1
                I got a RadioLink as my entry into 2.4Ghz. Rock -bottom prices from GiantCod tempted me – I think it was around £20 for a combo, with spare receivers at £7.
                Amazingly, they are CHEAPER now! You can get a 4-channel from Hobby King for £17, and a 6-channel for £18. I see new receivers on ebay for £3. These are cheaper than a transmitter strap used to be…
                #61372
                  I've handled several of those stupidly cheap radios and I wouldn't put one in any model which I wasn't prepared to lose or damage. They are cheap because they are made to go into toys which by their nature don't last for very long, and they are stupidly cheap because they use poor-quality or even reject-grade components; are badly assembled by low-paid workers and have no Quality Control.
                  I was talking to a guy very recently who insists on buying the very cheapest speed controllers he can find, direct from China. He buys them in tens. When I asked him why, he told me that that – of the ten – only four would work at all and of those four only one would continue to work. When that one finally goes bang he buys another ten. At four pounds each that means he pays £40 for one poor-quality ESC which is pretty much bound to go wrong sooner or later. Utter lunacy.
                  Only by cutting every corner possible can electronic equipment be made for that price. As I wrote somewhere once, if you pay a lot then you might not get everything that you expect, but if you pay peanuts then you'll most likely get everything you deserve. I've stated publicly that I wouldn't pay any less than £80 for a Tx/Rx 4-5 channel combo; I've seen nothing to change my opinion.
                  Dodgy Geezer 1
                    @dodgygeezer1
                    Posted by Dave Milbourn on 13/11/2015 14:11:45:
                    I've handled several of those stupidly cheap radios and I wouldn't put one in any model which I wasn't prepared to lose or damage. They are cheap because they are made to go into toys which by their nature don't last for very long, and they are stupidly cheap because they use poor-quality or even reject-grade components; are badly assembled by low-paid workers and have no Quality Control…………
                    …………………if you pay peanuts then you'll most likely get everything you deserve. I've stated publicly that I wouldn't pay any less than £80 for a Tx/Rx 4-5 channel combo; I've seen nothing to change my opinion.
                    Well, Radiolink also do £100+ radios which have quite a following stateside – so they must be able to do some things right…
                    The RadioLink T4Us are not intended to be toy radios – you can pick up toy transmitters on ebay for less than £10 – but they do have cheap trim, cheap switches, and the internal soldering is worth checking out before switching on. I've got three – they all work fine, but I did resolder the pot connection wires on one because, though working, one wire was only half soldered on.
                    I've got a variety of cheap escs (including the infamous blue heatsink one) and not had a dud one yet. But I do run them WELL below any claimed amperage on my small model boats – 2 or 3 amps at most for a claimed '50A' unit.
                    I can only go on my experience, which is that the quality control is low and they should never be run up to the maximum capability claimed, but, taking that into account, they can provide a functional cheap service. My oldest T4U has now had 5 slope soaring seasons and works fine to out-of-sight range. I suspect that the cheap price is also due to having little or no research costs, and making use of cheap mass-produced mobile phone or wireless computer parts rather than custom circuits.
                    The one area I might agree more fully with you is servos. These, of course, are items which wear, and I have had one or two miniature ones where the pot goes jittery after a couple of day's use – as likely to be down to poor assembly or dirt as much as cheap components. But the great advantage of boat building is that there's always a use for a servo motor and gear train..
                    Getting back to the original point, even discounting CCSs (Cheap Chinese Systems!), I would still say that a modern Radio Control is cheaper and more functional than the radios of the 1980s…
                    Edited By Dodgy Geezer on 13/11/2015 15:37:31
                    Edited By Dodgy Geezer on 13/11/2015 15:38:12
                    #61389
                    Peter Fitness
                      @peterfitness34857
                      I would definitely not use the cheap Chinese radios in aircraft, where a malfunction can be disastrous, however I am quite comfortable using them in boats. I have three of the cheap 2.4 ghz radios and have not yet had a problem with any of them, after up to four years of regular use. I completely understand Dave M's position on this, and I have a great deal of respect for his expertise in these matters, but I take the view that the worst that could happen to my slow model boats is that they cease to respond mid-lake. Should that happen which – touch wood – it hasn't so far, then it would be time to launch the rescue boat. I would also not use them in fast electrics where a malfunction could cause damage to other boats.
                      Peter.
                      #61394
                      Martin Field 1
                        @martinfield1
                        I bought a £45 Spektrum DX5e Tx. last year and an Orange £8 Rx, both of which have a pretty good name. Having eschewed model flying, I'm sure these will be fine for model boats, including yachts.
                        Cheers,
                        Martin
                        #61396
                          If you have a stupid-cheap Chinese radio which works for you then fine – it works for you. By the same token there are a lot of people who happily drive round in cars which are mechanically unsound and offer little protection in the event of a crash. As long as you're prepared for the possible consequences of buying the cheapest XYZ on the market then that's OK by me. Suit yourselves, chaps, and good luck to you.
                          I've seen and heard nothing to change my opinion, but it's only my opinion.
                            Hi Rob
                            I have been using a Hobbyking Turnigy IA6 2.4G system for 2 years and with number 8 model dialled into to it, I love the thing!!!
                            Supports up to 20 models off the one transmitter!!!
                            NO frequency problems with other modellers!!!!
                            Good price, change the servo direction in the menu, change the speed increase sloop on the servo(ESC) and the end stops on the servo(ESC).
                            Add sensors for rpm, temp and voltage.
                            Name the model in the menu and set it up the requires for that model.
                            For more bells and whistles the Turnigy IA10!!!!!
                            #61412
                            Dodgy Geezer 1
                              @dodgygeezer1
                              I was trying to talk about ALL the changes that have happened in modelling since the 1980s, to provide Rob with a bit of background, rather than a discussion on favourite radios……
                              #61413
                                Blimey! ALL? Here's my list of the changes in radio sets alone;
                                Servo reverse switches
                                Dual Rates
                                Dedicated VHF frequencies (Aircraft models only, ground models only)
                                Computer radios (with all that follows)
                                NiMH and LiPo/LiFE cells
                                Dial-up frequency VHF receivers
                                Piezzo gyros for helicopters
                                Mini and Micro servos (i.e. less than 20 x 20 x 40)
                                Microwave frequencies (2G4, 5G8)
                                Digital servos
                                Telemetry
                                Manufacture moved from USA, Japan and Europe to Taiwan, South Korea, Singapore, Philippines, ROC
                                Open-source software for programming transmitters
                                There must be more but they're the ones which come to mind… O, and a drastic reduction in prices (Bonner Digimite 8 channel radio in 1970 $800; Turnigy 6 channel radio in 2015 $50)
                                Favourite radio now – Hitec Optic 6 (2.4Ghz)
                                Favourite radio ever – Kraft Gold Medal Series 6 (27Mhz)
                                #61414
                                Dodgy Geezer 1
                                  @dodgygeezer1
                                  Posted by Dave Milbourn on 14/11/2015 12:54:21:
                                  Actually, I was thinking of going wider than that!
                                  Radios are cheaper, and have more functions, true. And the move to 2.4Ghz allowing people not to worry about frequency clashes is a big difference. But if you have come back into modelling for the first time since the 1980s, there are other things – a few of which you mention, like mini servos small enough to mount IN a control surface and LiPos. Brushless motors is a biggie. Outside eloectronics there are new materials and the spread of specialist glues. The arrival of national and international modelling forums on the web.
                                  And the downsides. Fewer model shops. Many fewer venues to fly or sail. The move from built-up models to ready-to-run. The rise of internet purchasing. Are the last ttwo bad or good…?
                                  #61416
                                  rob smith 4
                                    @robsmith4
                                    Thanks all.
                                    Its the 2.4ghz radios , brushless motors and LiPo batteries where i'm lacking the knowledge.
                                    with the info given above i'm now a little better informed to make a choice.
                                    Rob
                                    #61421
                                    Dodgy Geezer 1
                                      @dodgygeezer1
                                      2.4Ghz radios:
                                      – are generally cheaper than the old lower frequency radios. And have a very small aerial.
                                      – Same Tx can be used for air, car or boats. But not submarines. TXs are usually designed for airplane, car or helicopter/drone operation, rather than boats…
                                      – don't have a specific spot frequency that they work on, and don't use exchangeable crystals. Instead, each company's transmitters only work with a specified model receiver. Each specific receiver is 'bound' to a specific transmitter, often by pressing a button when the two are in close proximity. Thereafter, that receiver will only respond to that transmitter.
                                      – are better at rejecting interference than the older radios.
                                      – will allow very many models to operate simultaneously, with no need to check frequencies with other users.
                                      Brushless motors:
                                      – come in two types, inrunners and outrunners. Inrunners are high-speed, out-runners are high-torque
                                      – require a brushless speed controller to work. They won't work on their own, or with a brushed speed controller
                                      – have 3 wires going into them, which are connected to the 3 wires coming out of the controller, in any order. To reverse direction, reverse any 2 of the wires.
                                      – brushless speed controllers often undertake a process called 'programming' when they are attached to a motor. This can be confusing to new users, and if you have poor Chinese instructions this doesn't help. Incidentally, another reason to be cautious of cheap Chinese equipment is the lack of coherent instructions and after-sales support…
                                      – Can put out alarming amounts of power at very high revs , from quite a small, light unit.
                                      – unless you get a special expensive 'sensor enabled' motor and controller, they are not very good at low speeds. In particular they tend to start with a jerk. 2.4Ghz transmitters and brushless speed controllers often have specific failsafes built into them requiring users to drop the throttle to low power before the motor will start.
                                      – need a good high-output battery to provide the power they are capable of. This doesn't have to be a Lipo, but for aircraft it usually is…
                                      – are very difficult to size for a particular model, since the same motor is usually capable of running on a wide variety of voltages (sometimes 20v or more) and providing a wide variety of power outputs. They use a measure called 'KV' – look it up…
                                      LiPos:
                                      – are very light batteries with low internal resistance, capable of holding a lot of power and releasing it quickly.
                                      – comprise 1 or more cells, each with a nominal voltage of 3.7v. Fully charged they are 4.3v, discharged they are 3v.
                                      – are very dependent on proper handling, charging and discharging. Exceeding limits by a minor amount can damage the battery, and so a specially precise charger is used. If the batteries are damaged, they may ignite fiercely, so care needs to be taken with them at all times, and specific handling procedures adopted. Continuous battery monitoring is recommended.
                                      – Brushless speed controllers often monitor the battery they are connected to and cut power if unsafe LiPo voltages are experienced. This feature is set up during programming, and can be very confusing if you do not realise what is happening…
                                      Edited By Dodgy Geezer on 15/11/2015 00:00:56
                                      Edited By Dodgy Geezer on 15/11/2015 00:01:48
                                      Edited By Dodgy Geezer on 15/11/2015 00:05:26
                                      Edited By Dodgy Geezer on 15/11/2015 00:07:54
                                      Edited By Dodgy Geezer on 15/11/2015 00:09:08
                                      Edited By Dodgy Geezer on 15/11/2015 00:15:43
